R50/53 JDM tail lights
Old Jan 9, 2016 | 06:33 PM
Minicruzer08's Avatar
Minicruzer08
JDM tail lights
So I ordered these new tail lights. But there is something custom I want to do but not sure if possible.
The problem I have with the R53 is the reverse light being so low and not so bright.
What I want to do with these new tail lights is change the signal to reverse lights. And the middle light to signal. And keep the bottom lights the same.
Thanks for any help.
Old Jan 11, 2016 | 06:04 AM
Saltysalt's Avatar
Saltysalt
those are nice lights... haven't seen that kind yet, where did ya find them?
as for wiring , you just need to spend some time with a multi meter. since your not really doing anything drastic
Old Jan 12, 2016 | 06:49 AM
Minicruzer08
I got them on eBay. And thanks for your help.
Old Jan 12, 2016 | 01:43 PM
chrisreese's Avatar
chrisreese
I have these same lights, but the smoked version. Anyway, the problem is that you will have to change the LED's on the top to white since they are yellow to start with. If you managed to rewire them as they are, your reverse lights would be yellow.
Old Jan 13, 2016 | 07:14 PM
mikewitdaspike's Avatar
mikewitdaspike
I find it amusing they call them JDM... None of the R53s I've seen over here have those lol. As the guy above me just said, the main problem is the top LEDs would still be yellow unless you changed out the resistors (I believe, unless those LEDs are the kind that come with them attached, then you'd have to change the whole panel out).
Old Jan 13, 2016 | 07:46 PM
Minicruzer08
Would any of you know another solution for more reverse lights?
also below are the links to the lights and a video of them.
http://www.ebay.com/itm/2001-2004-MI...tV-i15&vxp=mtr
I also thought about buying these LED Light bars and mounting them in the grill in the rear bumber.
Old Jan 14, 2016 | 06:19 AM
Saltysalt's Avatar
Saltysalt
while you could do those light bars, they will produce ALOT of light haha. There are some single LED's that you can use and you could hide them in the grills.
Flygirl
Dec 10, 2018 11:13 AM
somcallmetim
Dec 18, 2015 01:05 PM
zakindi
Dec 16, 2015 11:45 AM
lyonsfin
R55 :: Clubman Talk (2008+)
Dec 13, 2015 05:54 PM
DustinFennell
Dec 12, 2015 05:44 PM
