R50/53 schwaben Mini/bmw scan tool
Old Jan 5, 2016 | 08:42 PM
12magnum's Avatar
12magnum
anyone familiar with this tool? it says performs most adaptions. does this mean it can clear a long term adaptive code like a PO2096 code?
https://www.ecstuning.com/Search/Sit...99__ES2992111/
Old Jan 6, 2016 | 04:52 AM
bavmotors's Avatar
bavmotors
I wonder if this tool varies from the ones sold on eBay. The eBays seem to have the save abilities but I was unable to code my R53 with it though.
Old Jan 6, 2016 | 05:24 AM
Saltysalt's Avatar
Saltysalt
have you asked ECS?
Old Jan 6, 2016 | 06:12 AM
Helix13mini's Avatar
Helix13mini
Haven't seen that one, but the Bavarian Technik tool is a factory scan tool emulator, meaning that it sees all proprietary modules, clears all codes, and even datalogs. It's basically a factory tool on your laptop.
Old Jan 6, 2016 | 11:09 AM
bavmotors's Avatar
bavmotors
if only it worked with Mac, it's 2016 we need Mac compatible software.
Old Jan 6, 2016 | 11:56 AM
We plan on testing this more soon. There are lots of different things it does between chassis . Most adaptations can programmed / reset and it programs the new module to factory ( old setting ). Most of all, it will read faults in the car more in-depth like HVAC faults, ABS faults and will tell you will corner is bad. Found some old log info on battery faults due to a low voltage battery, like a history lesson on your MINI. More of a in depth scanner then coder.
The more info we find for MINI specifics per chassis we will post up.
Old Jan 6, 2016 | 12:51 PM
Helix13mini
We use an ancient dedicated laptop in the shop. It works great and would cost about $25 on Craigslist.
Old Jan 6, 2016 | 01:07 PM
bavmotors's Avatar
bavmotors
so it's not a real taxing application on pc hardware then?
Old Jan 6, 2016 | 01:12 PM
Helix13mini
Exactly. But don't be fooled, that doesn't mean that the program isn't sophisticated. Talking to a car isn't like video editing: it doesn't need tons of processing speed. Even with an arsenal of professional scan tools, we still use the BavTech for certain tasks.
pppdxx
May 28, 2023 09:17 AM
scatpack
Jan 10, 2016 09:43 AM
dhessel
Jan 5, 2016 10:58 AM
Suspension Products
Jan 4, 2016 04:10 PM
