Silver wheel paint
Old Jan 3, 2016 | 07:10 PM
MNMLST's Avatar
MNMLST
Silver wheel paint
Can someone please recommend a paint that would give me a glossy silver finish? Just a bright silver like on the lip of this wheel. Not chrome or glittery metallic.
I have these exact same wheels on my MCS. I curbed it and I want to fix it using the Bondo method. I want to keep the same color and finish.
Old Jan 3, 2016 | 09:34 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Unless the wheel finish is painted where you want to repair it you won't be able to color match it well.
From your picture it seems the finish on that wheel is all polished aluminum.
If so, you can try to sand the damage flat then polish it.
Old Jan 4, 2016 | 01:09 PM
MNMLST's Avatar
MNMLST
I hadn't thought of that. Thanks!
I found a video:
Old Jan 4, 2016 | 02:46 PM
Capt_bj's Avatar
Capt_bj
good video ... a few comments
if you don't want to DIY check your yellow pages for a wheel repair guy .... often they run around with their shop in a trailer and can do this for you at home or work
note that the sanding I see in the video is all WET .... that is the way I'd do it too
I'd use masking tape liberally around the tire and parts of the wheel you don't want to touch .... just in case!
Got a Dremel????? Judicious use of a sanding disk followed by a buffer wheel can make this an even easier job
This works for fairly light curbing .... if you really GOUGED the wheels, you'll have trouble rectifying things this way. And on a polished rim, bondo is a poor solution. EASTWOOD has a 'paint on chrome' but is is $$ and I do not believe it would work well in this application. I'd refer back to those guys who do this regularly and maybe from a trailer . . .
Old Jan 4, 2016 | 03:56 PM
whaap's Avatar
whaap
If you end up having to use a paint product, do the same to the other three wheels.
Old Jan 4, 2016 | 05:36 PM
danjreed's Avatar
danjreed
http://www.bavauto.com/fland.asp?par...GwMaApKl8P8HAQ
Factory wheel paint for most German wheels.
nels415
Oct 17, 2017 06:29 AM
Robert Pritchard
R55 :: Clubman Talk (2008+)
Jan 29, 2016 05:12 AM
watchluvr4ever
Jan 19, 2016 02:12 PM
JAG33304
Jan 3, 2016 01:56 PM
Caton Brough
Jan 2, 2016 10:27 AM
