R50/53 Knocking sound in engine
Old Dec 29, 2015 | 11:38 PM
mhopper49's Avatar
mhopper49
I have an 05 mini s with 150k, keep up with all regular maintenance. While at a red light today I noticed a loud knocking sound, or louder than normal. After I got the car home I sat in it for a few min at idle, she sounded normal. Any idea at all what this might be. I recently got my seat recall done and while talking with the mini mechanic I asked him about the timing chain tensioner. He said on 05s he has never see one that needs replaced.
Old Dec 30, 2015 | 06:45 AM
nkfry's Avatar
nkfry
Is the car a manual? Probably clutch chatter, which isn't uncommon.
Is there oil in the car? A timing chain is more of a clattery racket than a solid knocking.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 30, 2015 | 07:28 AM
Throw out bearing rattle ? Can you hear it in front on the driver side.
Old Dec 30, 2015 | 08:12 AM
Helix13mini's Avatar
Helix13mini
If the sound goes away when you press the clutch in, It's your dual-mass flywheel. That can be intermittent. With the car idling and out of gear, depress and release the clutch pedal. If it goes away and comes back that's your issue. Depending on the condition of your clutch components, it may be best just to ignore the sound, since it's expensive to fix.
Old Dec 30, 2015 | 09:03 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Check your oil level and if the noise comes back first thing I'd do is determine where the knock is coming from.
888.280.7799 | 6am - 5pm PST
Old Dec 30, 2015 | 09:39 AM
sssevita's Avatar
sssevita
On my '03 R53 I had a loud knocking sound and it turmed out to be the sound made by improperly torqued loose spark plugs that had unscrewed themselves over time. I found out when one of them was blown out of the cylinder head taking 2/3 of the threads in the head with it. A Time Sert fixed it and I torqued all the new spark plugs to the proper torque (22 foot lbs if I remember correctly). Knocking sound went away after that.
Old Dec 30, 2015 | 09:41 AM
PelicanParts.com
Vendor
Spark plug torque is 27Nm (20 ft-lb).
Old Dec 30, 2015 | 10:14 AM
mhopper49's Avatar
mhopper49
The sound went away when I pressed the gas only not the clutch. I will give my spark plugs a look.
Old Dec 30, 2015 | 10:55 AM
Let me know what you find, loose spark plugs can cause a miss or noise. Check them out asap.
lalroma
Sep 25, 2019 07:40 PM
joarda
Dec 21, 2015 07:18 PM
gchin
Dec 4, 2015 09:19 AM
Dec 3, 2015 11:18 AM
jiggerachi
Dec 2, 2015 07:31 AM
