R50/53 Expected life span of run-flats? Cost to replace?
Hi
I like to plan ahead for large expenditures. I know replacing my run-flats won't be cheap. Any idea of estimated replacement costs? Also, how many miles might I hope to get out of these tires (17" performance)?
If you replace with run-flats, you can get the Dunlops 205/45 R17 SP 9000 Sport DSST's from the tire rack for right around $175 a copy. However, if you decide to get regular tires, you can get something like the Yokohama AVS ES100 for about $100 less (and a can of fix-a-flat). It just depends on how risk averse you are.
Just cleaning up the multiple posts. Here are the comments from the other thread.
Originally posted by johnandrhonda:
I damaged one in a pothole. Replacement was $235 at Discount tire, incl. mount, balance, and tax. Frankly, if I had it to do over again, I would get 16 inch and a spare.
Originally posted by YuccaPatrol:
Take it from a guy who knows a thing or 2 about the cost of replacing tires on a FWD Pocket Rocket: Tires for 16" wheels are so significantly cheaper than those for 17" wheels that it is not even funny.The sidewalls of a quality set of modern tires are incredibly rigid and the 17's are only a fashion accessory.
I was just wondering if anyone is running normal tires with a can of fix-a-flat as backup. DaveInDenver, I'm in Denver too. I'm gonna be ordering my MCS from Schomp next month. Woohoo!
Owen
Owen
Owen, I have a set of MINI R84 V-spokes with 205/50 R16 Yokohama AVS ES100 tires. They cost about $75 per copy. I also carry a cellphone, my roadside assistance card, fix-a-flat, and a small compressor.
If you haven't already done so, join the DenverMINI yahoo group.
Ok Dave. I went ahead and joined the Denver group even though I will only be in Colorado for another 2 weeks. I will likely be getting my mini the first of December in Nashville.
I've got these in 17s...thanks to Dave. Great tires once they are warm.
I don't even bother with the compressor. :smile:
DaveinDenver,
you have the V spoke S standard? I don't remember the rim option number...
and does the Yokohama rub at all?
The Yokohamas do not rub in the 205/50 R16 size.
blackie
Jan 18, 2017 09:56 PM
squawSkiBum
Oct 2, 2015 09:21 AM
JPMontes3
Aug 23, 2015 01:26 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
