R60 All4/S with 235/50 R18 - No Lift
Old Dec 23, 2015 | 07:36 AM
moron95m3's Avatar
moron95m3
Hi Guys,
I know there are a few threads out there that try to say what does or doesn't fit the R60. Wanted to create a thread to show some pics of probably the biggest tire setup you can fit, reasonably, without a lift.
Hope this helps.
Wheels: LM Reps - 18x8 et 35
Tires: Michilen Xice - 235/50 R18
Issues: Slight rubbing on driver rear on high speed whoops. I have NOT tried trimming, but the rub is where the fender flare curls under into the wheel well - I believe trimming will be simple, just remove a few mm of that plastic.
In another thread about snow tires, a member said he ran this size tire with an ET41 wheel and had no rub.
GIMG_5351 by Eric W, on Flickr
GIMG_5342 by Eric W, on Flickr
GIMG_5345 by Eric W, on Flickr
GIMG_5364 by Eric W, on Flickr
Old Dec 24, 2015 | 11:45 AM
Looks nice , might have to shave those rear arches on the inside as with that offset you will have some poke with the width.
Style 716 and style 030 are popular also ,
https://www.ecstuning.com/Mini-2011-..._Alzor_VMR_NM/
Old Jan 1, 2016 | 01:21 PM
tournot97's Avatar
tournot97
Looks really nice...... I bet with a lift you could go to a little bigger tire
Old Jan 2, 2016 | 05:27 PM
bmwr606's Avatar
bmwr606
the 235/50R18 tires are 27.3 inch OD
i run 205/70R16 Dunlop grandtrek sj6 AT winters on mini oem alloys, 16x6.5 et 46
they also are 27.3 inch OD
also tried 215/70R16 and 205/75R16 but they both rubbed on compression and the fronts rubbed at full steering lock
i have no rubbing at all with this setup and i have the sport suspension, 1 cm lower than the stock suspension ... loaded the car with 6 200+ pound guys, 2 sitting on the boot lip, suspension sitting down on the bump stops
i wanted the tallest possible sidewall for wheel protection from chicago potholes, do far so good ... on the 4th winter with no dinged wheels
a side bonus of the 16 inch tires is price ... $83 each
Attached Thumbnails All4/S with 235/50 R18 - No Lift-100_1922.jpg   All4/S with 235/50 R18 - No Lift-100_1918.jpg   All4/S with 235/50 R18 - No Lift-100_1920.jpg
Old Jan 2, 2016 | 05:28 PM
bmwr606's Avatar
bmwr606
btw ... bought the mini euro oem 16 inch alloys from ecstuning
Old Jan 4, 2016 | 09:01 AM
Yep, right here, I have not seen another CM with these on in person, very rare.
https://www.northamericanmotoring.co...an-s-all4.html
Old Jan 4, 2016 | 11:53 AM
Scottke's Avatar
Scottke
Looks great. Must ride nice too.
Old Jan 4, 2016 | 12:06 PM
VagabondSteve's Avatar
VagabondSteve
Brilliant!
Did they ever find that Fiat that went into that pothole up there last winter? Just kidding. It looks like a brilliant solution that also saves a pretty fair amount of coin! It always torques me how much more the larger diameter tires cost.
Old Feb 20, 2024 | 04:26 PM
mrgreen's Avatar
mrgreen
curious for your thoughts @moron95m3 if you're still out there
https://www.northamericanmotoring.co...5-50-18-a.html
Scm68
Dec 26, 2015 08:16 PM
krawzdogg
Nov 17, 2015 09:29 AM
GimmeBoost
Nov 12, 2015 11:19 AM
Jeffob5
R55 :: Clubman Talk (2008+)
Nov 11, 2015 12:38 PM
