R56 Power cut out and clicking?
Old Dec 16, 2015 | 10:02 AM
tylewis's Avatar
tylewis
Driving to work this morning and for a brief, fleeting moment, power cut out and was accompanied by "clicking"? Driving in fourth I believe, WOT, at relatively low revs (3-4K).
I cannot tell if it was boost that cut out or power entirely.
Anyone have any idea as to what this could be, be a sign of or be reason to further investigate.
This has happened before but these episodes are far and few between. This was the first time I heard what I describe as the clicking while power was gone. Almost like the car was working to get power back to...something, I don't know.
Old Dec 16, 2015 | 06:45 PM
GAT's Avatar
GAT
I honestly have no idea what could have caused that but based off the way you described it it sounds like your car stalled and restarted via the "rolling start" method. Can you tell if that's what actually happened? Is it manual or auto?
Old Dec 17, 2015 | 08:28 AM
Thats what I was thinking, or the throttle body adjusting to get more air from the loss air and its throttling on its own to gain back. I would post a video or sound clip, might be a sticky throttle body. Are you getting a CEL ?
Old Dec 17, 2015 | 05:05 PM
tylewis's Avatar
tylewis
No CEL or codes. As I have said this happened before under WOT. I cannot say with certainty, but I am almost positive the car did not stall and then roll-start again. An issue with the turbo sounds most likely. Maybe boost pressure cut out for a moment for whatever reason (misc. malfunction) and then resolved itself. I am not concerned, vehicle has been performing perfectly since then-under heavy downpour and sunny skies. Thanks everyone, everything should be fine.
Old Dec 17, 2015 | 06:18 PM
SpuuDy's Avatar
SpuuDy
I had the same problem a few months ago... (R56 mini n14) Thanks to a warranty the dealership gave to me with my car, they had to replace the timing chain at their cost. Are there puffs of white smoke coming out the back when this happens? If so it sounds a lot like my problem..
Old Dec 17, 2015 | 06:36 PM
Genzox's Avatar
Genzox
I just had the same thing happen to me today! I had this problem a couple of months ago, I have since done a timing chain and it just did it again....
Old Dec 18, 2015 | 12:39 PM
tylewis's Avatar
tylewis
Same here, the first time or two happened before the timing chain replacement. The third (most recent) done after timing chain replacement. No idea about the white smoke.
Old Dec 18, 2015 | 08:11 PM
SpuuDy's Avatar
SpuuDy
Yeah I had my timing chain replaced and it stopped happening for a little... It happened the other day from 2nd gear - 5th gear (it only happens now very rarely). I added oil because it was a little below the half way mark on the dip stick and that seemed to help a little. I've done some reading and hear a lot about carbon build up in the intake. I might run some sea foam through it in hopes it coughs this stuff up and drives fine.
Old Dec 19, 2015 | 09:15 AM
tylewis's Avatar
tylewis
I haven't heard of any noticeable results from seafoam treatment. From what I understand, walnut blasting is the only worthwhile procedure. I plan on having that done within the next 2 months and will make a post about the effects.
Old Dec 21, 2015 | 11:55 AM
+1 for walnut blasting.
https://www.northamericanmotoring.co...-cleaning.html
ragingMINI
Oct 26, 2020 12:52 PM
okeyes
Navigation and Audio
Jun 26, 2019 04:43 PM
JamesDeBart
Dec 22, 2015 04:46 PM
WayMotorWorks
Nov 25, 2015 11:08 PM
embiggenedmini
Nov 18, 2015 12:34 PM
