Steering wheel vibration after installing wheel spacers
Old Dec 16, 2015 | 05:47 AM
Goop's Avatar
Goop
Has anybody experienced steering wheel vibration after installing wheel spacers?
Old Dec 16, 2015 | 06:18 AM
TWISTER's Avatar
TWISTER
sounds like they are not seated correctly or maybe you need hub centric rings installed
Old Dec 16, 2015 | 08:59 AM
RB-MINI's Avatar
RB-MINI
+1, what size are they, and what MINI? Also, on the R50-53's the lip on the hub is 10mm and if you run a 10mm spacer, there's no more lip for the wheel to center itself. I'm not sure what the distance is on the other models, though. Do your spacers have a lip?
Old Dec 16, 2015 | 09:38 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
What size did you go with? I have seen this complaint more than a few times when the spacers aren't hubcentric. Some brands only make 10mm+ spacers hubcentric. You can see explains of them HERE. Look at the RaceMax 5mm spacer compared to their 12mm spacer.
888.280.7799 | 6am - 5pm PST
Old Dec 16, 2015 | 01:04 PM
+1 , or rust on the hub , wheel, or rotor hat. Make sure you have the correct spacer for the year, has to be the right Center Bore also.
Old Dec 16, 2015 | 03:46 PM
Goop's Avatar
Goop
Hubcentric 15mm spacers on 2006 R53.
Old Dec 17, 2015 | 06:56 AM
Check the rust and make sure they the correct CB.
Old Jan 10, 2019 | 02:42 PM
einstein_314's Avatar
einstein_314
How's the handling with wheel spacers? Any notable changes from stock?
When I bought my F60 JCW a few months back I need to get winter tires for it. In the end I went with the factory option which they gave me a decent deal on. But before I decided on that I was having a heck of a time finding a wheel that would actually fit on the F60 JCW. No tire shop in town could do anything for me and most online places (TireRack, etc) don't even list the F60 JCW in their systems or when they do there are no compatible wheels. Several local shops called their suppliers and all said that there is no mass produced wheel that will fit over the JCW brakes without spacers. MINI confirmed this (although they might have been pushing me to buy their option) and really cautioned me against using spacers because it would have unknown effects on handling. I considered spacers anyways but without having the car on-hand to measure things wasn't sure what size I would need to make things work.
So for my future reference, is there really any handling problems with using spacers as you guys are?
Old Jan 11, 2019 | 05:30 AM
When we installed 20mm on the my R58 JCW and R52 MCC JCW it improved the handling and made it feel a little sharper as the track is now wider. You can feel it in the smaller MINIs, in the new bigger MINIs I have not driven one with spacers,based on the ride is more sedan like I imagine it will be less felt unless you have a tighter suspension. The JCW CM might the tighter to you might feel that change in handling. Use that video guide above to measure for fitment on the wheels. On aftermarket wheels that dont fit without spacers you can tape up the caliper and have someone hold up wheel as close to the caliper and eye up the distance you need ( use a small caliper tool or tape measure) and try to find that gap from the wheel to the top of the rotor hat. Or you can rent out test tool also linked.
We have the Gen 3 F54-F60 wheel spacers here, they fit F60 also.
https://www.ecstuning.com/News/Mini_...Wheel_Spacers/
Test tool https://www.ecstuning.com/b-ecs-part...202ecs03lktkt/
Old Dec 12, 2019 | 06:49 PM
jk6672's Avatar
jk6672
Posted in wrong thread
Old Dec 15, 2019 | 08:13 AM
Blue R50's Avatar
Blue R50
I personally would not run them for engineering reasons. Wheel bearings like to be centered in the wheel so that the forces are balanced. Excessively offsetting the wheels alters this relationship and can cause them to wear prematurely. For this reason, I would not do this to a car you drive every day. If you must run them, I would run spacers that have built in studs and bolt to the hub. Just using a spacer between the wheel and hub is a weak setup and can stress the wheel studs or bolts excessively. It will also eliminate the hub centering ring of the original hub and will make the wheel wobble. Whenever you make a change to a rotating part, always look at the underlying engineering that the original designer used to keep things spinning straight and true and figure out if you are going to negatively impact it.
drewstermalloy
Tires, Wheels, & Brakes
23
Apr 24, 2017 08:37 AM
Isyvibes
Sep 2, 2016 01:10 AM
gschiel
Feb 3, 2012 09:31 AM
MUShadd
Suspension
Apr 8, 2009 03:15 PM
thejunkman
General Discussion
Jul 16, 2003 08:32 AM
