R50/53 Why no nGauges for R53?
Old Dec 14, 2015 | 07:53 PM
Tata Steva's Avatar
Tata Steva
I got my great little R53 last May...
I need better gauges.
I don't like to loose vent with P3cars solution...
I don't want to install additional wires and modify the engine to put conventional set up...
I don't want scangaugeII (any more, had it for years in previous MINIs)...
I want those nice looking CravenSpeed (OBDII) nGauges, only to find out they don't work on first generation due to lack of software (old protocol???).
Come on, CravenSpeed!
Is it that hard?
You don't want my money?
Old Dec 15, 2015 | 07:53 AM
The OEM gauges are all NLA, upper and lower gauges for Gen 1 MINIs :(. The P3 cars , you don't loose the vent function , still vents, just loose the rotation function of the vent. And it looks very clean installed. Its a quick install.
VIDI gauge
https://www.ecstuning.com/News/MINI_...006_2007_2008/
Boost gauge
https://www.ecstuning.com/News/MINI_...s_Boost_Gauge/
Old Dec 15, 2015 | 08:07 AM
Tata Steva's Avatar
Tata Steva
Actually, you do loose "control" over the vent once P3cars device is in (no adjustment of direction or closing it if you don't want it). Corect me if I'm wrong please.
Second, when I am in my "driving position" and comfortable handling the steering wheel (in it's ideal position FOR ME), I don't see the left vent where the gauge should be...
It is blocked by JCW steering wheel rim. I just can not "glance" at the P3 gauge like with all other visible displays (tach in front thru steering wheel or "pizza" speedo in the middle). So, that set up won't be any different from what I have now: ScangaugeII mounted bellow toggle switches (just like OEM additional gauges- the reason I never with with those).
I might as well keep SG then...
Ideally, I loved what I had in my R55s and R61 (JCW OEM gauges right next to tach in the middle).
I love CravenSpeed (old) mounting solution with "X" bracket and 52mm cups (just got one of the very last "X" brackets available from Detroit Tuned). I really like the design and finish of the hardware. BUT, so disappointing not being able to use their version og OBDII gauges on my car...
Still looking...
Old Dec 15, 2015 | 09:05 AM
MINIAC's Avatar
MINIAC
Craven makes a Scangauge specific tach mount.
Old Dec 15, 2015 | 09:14 AM
Tata Steva's Avatar
Tata Steva
Thanks, I am aware of it.
But that is fugly!
I am trying to get rid of SG all together. Never liked the "design" of it. It was (and still is) a necessity only, rather than being "in sync" with design of the MINI interior. I am sure I'm not alone thinking SG is one ugly display. All "boxy", looks more like USSR made gadget than anything...
I simply want to get "analog looking" gauges (with needle) with out doing all "dirty work" of installing sensors and wires in my gorgeous MINI...
This is how interior looks now (before I put in a SG)
Old Dec 15, 2015 | 09:45 AM
MINIAC's Avatar
MINIAC
If you want a scan gauge that will fit in a 52mm pod there's the Aeroforce Interceptor ...
The gauge displays 2 parameters at a time, but can be programmed to cycle through up to 8 parameters during a user determined period of time. This way you can monitor several items without taking any other actions.
You can cusomize the face and/or bezel.
$$ Pricey $$
Old Dec 15, 2015 | 10:10 AM
Yea, Thought you meant the vent does not vent air, yea, no close or direction. But its seamless look, integration, and color coded to match the color of the other leds and display. Its the right vent, next to the speedo and in upright seating position you can see it. Unless you have the seat much closer, then it does catch the thicker steering wheel.
Good luck on the search.
Still looking...
Old Dec 15, 2015 | 10:30 AM
Tata Steva's Avatar
Tata Steva
$$ Pricey $$
Not "analog look" but more along the lines what I want. It sure looks like an option. Price? Cheaper than P3...
Old Dec 15, 2015 | 10:54 AM
MINIAC's Avatar
MINIAC
About the same if you add $20 to customize the gauge and $105 for Craven Bracket Z and 52mm cup, but this one looks to have more features.
Plus the steering wheel would block my view of the P3 in the vent to the left of the speedo.
Keep us updated if you decide to go with the Aeroforce.
Old Dec 15, 2015 | 11:11 AM
Tata Steva's Avatar
Tata Steva
Yeah...
I just can not figure out what "model" of Interceptor is good for R53 and is there a double gauge option...
Old Dec 15, 2015 | 01:34 PM
MINIAC's Avatar
MINIAC
Yeah...
1st Gen is ISOi according to their applications guide ...
Doesn't look like there's a dual gauge for this version.
Old Dec 15, 2015 | 01:45 PM
Tata Steva's Avatar
Tata Steva
Yup.
Got the confirmation from the source...
Old Dec 15, 2015 | 01:52 PM
MINIAC's Avatar
MINIAC
Are you going for custom bezel and face?
What color display?
Old Dec 15, 2015 | 01:57 PM
Tata Steva's Avatar
Tata Steva
What color display?
display color is another issue: does that refer to background color or digit/letter color?
I would go with standard faces (black and white comes in kit) and polished ring to match my tach trim.
Old Dec 15, 2015 | 02:06 PM
MINIAC's Avatar
MINIAC
Apparently the display is reversible ...
Wouldn't you want a silver gauge face with polished silver bezel to match your tach?
Old Dec 15, 2015 | 02:27 PM
Tata Steva's Avatar
Tata Steva
Thanks for the photo! White display it is...
I will order standard kit first. It comes with extra face. I will refinish it in what ever color I find appropriate once I mount the gauge.
Old Dec 15, 2015 | 02:38 PM
MINIAC's Avatar
MINIAC
Is the inclusion of the extra gauge face noted on the site?
Old Dec 15, 2015 | 02:44 PM
Tata Steva's Avatar
Tata Steva
yup
Old Dec 15, 2015 | 03:26 PM
MINIAC's Avatar
MINIAC
Please provide pictures and feedback if you go this route.
Old Dec 15, 2015 | 03:52 PM
MINIAC's Avatar
MINIAC
Silver face Interceptor on R56 ...
Old Dec 15, 2015 | 04:20 PM
Tata Steva's Avatar
Tata Steva
That silver face does look nice !..... Hmmmmmmmm
Now, what would be the easiest and best place on R53 to tap in for 12V power?...
Old Dec 15, 2015 | 04:36 PM
MINIAC's Avatar
MINIAC
Instructions don't mention MINI ...
Old Dec 15, 2015 | 04:55 PM
Tata Steva's Avatar
Tata Steva
T
Didn't realize this was a requirement ... maybe I won't be swapping my Scangauge for one of these.
It's not clear if it does or not. It just says (on web page) that "some older models" require this. I am not sure if R53 is one of those...
I sent the question to Aeroforce, keep you posted.
In any case, that is not a big issue. Cigarette lighter plug comes to mind...
Old Dec 16, 2015 | 09:37 AM
MINIAC's Avatar
MINIAC
I sent an email to Aeroforce asking if they have pictures of the brushed aluminum bezel with silver face gauge. The President got back to me and said they would in about 3 weeks. Apparently they're going to have an MINI logo option for the gauge face ...
I replied back asking about the 12V power requirement and if amber lighting (to match stock) might be a future option.
I don't like messing with anything electrical.
Old Dec 16, 2015 | 09:45 AM
Tata Steva's Avatar
Tata Steva
That logo looks nice!
When will it be available?
Got the answer: it does require 12V power hook up...
I don't like either to mess with wires, but decided to go and do it after all. Spent last night reading all possible posts on NAM about "add a fuse" or "tap a fuse" and I will go for it... (it really looks simple...)
