R50/53 2005 R53 Daytime Running Lights Ceased Working
Old Dec 13, 2015 | 09:16 AM
overs001's Avatar
overs001
Hey, does anyone have any idea how to fix my daytime running lights. Just installed new H-7 bulbs after noticing both of my DRL's weren't working. I have Zenons for the nighttime lights. The fusible links are ok. Is there a relay I'm missing? At a loss because the regular lights work and the high beams (H-&'7) are working fine. HELP!!!
Old Dec 13, 2015 | 02:11 PM
MiniSMan's Avatar
MiniSMan
where in the Headlights are the DRL's located on a 2005 and 2006 Mini ??? I would like to enable that feature on my 06 MCS
Old Dec 13, 2015 | 02:42 PM
Scanner's Avatar
Scanner
maybe a blown fuse? funny they would stop all of a sudden...did it happen after you changed the other bulbs...maybe a plug got loose/disconnected
Old Dec 13, 2015 | 02:57 PM
Martin Brenneke's Avatar
Martin Brenneke
I have a 2005 r53s . Mine does not have daytime running lights. Have to use the stalk to get any lights other than fog lights to work.
Old Dec 13, 2015 | 04:12 PM
rkw's Avatar
rkw
DRLs on R50/R53 are dimmed high beam headlights. It is a programmable option that can be enabled by a dealer or shop using software such as NCS Expert.
Old Dec 13, 2015 | 05:06 PM
Capt_bj's Avatar
Capt_bj
OP
sure you had DRL b4 the bulb change??????
if you did, then the bulbs must be the issue .... perhaps they don't like running at the low power setting the GEN1 DRL function employs ?????
Old Dec 14, 2015 | 07:36 AM
+1 , yea they are very dim high beams
Old Dec 14, 2015 | 03:29 PM
overs001's Avatar
overs001
They are in the bottom of the light housing below the Xenons.
Old Dec 14, 2015 | 03:32 PM
overs001's Avatar
overs001
It is funny. Fuses are ok. I've checked every fuse that has lights associated with it. I've had DRL since I bought it new in '05. Not sure when they stopped working, I thought that both bulbs had burnt out.
Old Dec 14, 2015 | 03:33 PM
overs001's Avatar
overs001
Like I said, I've had these since it was new. So perplexing.
Old Dec 14, 2015 | 03:35 PM
overs001's Avatar
overs001
Originally Posted by Capt_bj
OP
i definitly did have it before.
Good point. I think i may have an old bulb around where I've replaced both, but one bulb was still OK to use as a check. I replaced these with PIAA H7 Ion Yellow bulbs. i'm assuming these would work as DRL's.
Old Dec 16, 2015 | 03:00 PM
Capt_bj's Avatar
Capt_bj
did you verify a bulb issue? PIAA not waking up????
if not
car wasn't software reflashed for a service issue anywhere along the way was it?
If so, maybe they lost the DRL programming ..... it is something that can be turned on off
Old Dec 17, 2015 | 07:03 AM
DRL turned off at one time maybe when there was a computer flash update by the dealer ?
Old Dec 21, 2015 | 11:24 AM
overs001's Avatar
overs001
Not The Bulb
if not
I finally found the bulb and got the same results. Brights work but no running lights. I had the throttle body replaced and at that time they did a refresh of the software, so that must be it. It got turned off or not turn on at that point. Next stop is the dealer sadly.
Thanks everyone! As soon as I can I'll get to the dealer and have them take a look and let you know.
Old Dec 21, 2015 | 11:30 AM
Thanks for the update , yep looks like it was turned off.
silence2-38554
Dec 4, 2019 06:14 PM
WayMotorWorks
Dec 11, 2015 10:06 AM
WayMotorWorks
Dec 11, 2015 10:04 AM
escriba
Dec 10, 2015 12:39 PM
ad78
Dec 9, 2015 11:41 AM
