R56 Do Gen1 MINI factory wheels support TPMS?
Old Dec 10, 2015 | 06:29 PM
GimmeBoost's Avatar
GimmeBoost
I've read that wheels must be specifically made to support TPMS sensors. Can TPMS sensors be successfully added to factory Gen1 MINI wheels, or do I need to stick to wheels that come from a Gen2 MINI?
Thanks.
Old Dec 11, 2015 | 08:23 AM
Nope , was not till about 2008+ R56/ R55 MINI models ( very end Gen 1 of the 2008 convertible ) that the inboard wheel TPMS system was initiated. Before that the TPMS was read off of the wheel speed sensor / ABS sensor. So you can take TPMS wheels or NON TPMS wheel and put them on your gen 1 MINI. No problems. Taking Gen 1 MINI wheels with tire and putting on 2008+ Gen 2 you will need to add TPMS senors in each wheel. They will fit most wheel systems from Gen 1 MINIs. Split year in 9/2009 for the car it goes on , so watch that also.
https://www.northamericanmotoring.co...-question.html
Old Dec 11, 2015 | 09:20 AM
GimmeBoost's Avatar
GimmeBoost
Thank you! I know I have the early TPMS sensors, and that the Gen1 cars didn't come with them, but I wasn't having any luck finding information about adding TPMS sensors to Gen1 wheels. I only found references that the TPMS sensors didn't fit all wheel types without being any more specific.
Makes these Gen1 wheels that I picked for a song all the better, TPMS cost notwithstanding.
Old Dec 11, 2015 | 09:56 AM
Welcome, on the older gen 1 style wheels its case by case, most fit but I found some dont, but the Huf branded orange sensors are smaller near the neck so they have a better chance. Whats wheels did you get and fitting with TPMS sensors ?
Old Dec 11, 2015 | 12:56 PM
bugeye1031's Avatar
bugeye1031
Moderator
Gen 2 TPMS Sensors on R81 Imola Wheels (Holies)?
ECS Tuning-
Do you know if I can mount TPMS sensors on Holies? Considering this for my 2008 R52.
Old Dec 11, 2015 | 01:08 PM
Yes,
They brought back the hollies for the 10 yr anniversary (2012) MINI R56 Cooper and they have TPMS in the wheels standard. So yes.
https://www.ecstuning.com/Search/SiteSearch/R81_MINI/
Old Dec 11, 2015 | 01:14 PM
bugeye1031's Avatar
bugeye1031
Moderator
Yes,
Thanks!
Old Dec 11, 2015 | 01:42 PM
Welcome. Rare to see the 10 year anniversary MINIs only came in Cooper version.
Old Dec 11, 2015 | 11:42 PM
GimmeBoost's Avatar
GimmeBoost
These are the wheels I got. 16 inch. I believe they're R83 wheels.
Old Dec 15, 2015 | 05:25 AM
GimmeBoost's Avatar
GimmeBoost
Bump. These wheels work with Gen2 TPMS sensors?
Old Dec 15, 2015 | 07:42 AM
Dont think the R83 wheels will fit them as thats Gen 1 Wheel. From MINI : For vehicles with
Tire pressure display = NO
You would have to test fit one of the Huf brand orange ones as they are a hair smaller on the shoulders then the genuine MINI ones.
Old Dec 17, 2015 | 10:31 AM
GimmeBoost's Avatar
GimmeBoost
So it appears that the only real definitive way to know with certainty is to buy one Huf orange TPMS and take one wheel to a tire place to see if it'll fit properly? That sound about right?
The wheels currently have tires on them and I don't have the equipment to properly dismount a tire in my garage. I know Harbor Freight sells just the thing, but it takes up a decent amount of space.
Old Dec 17, 2015 | 12:08 PM
Yea, that's the only real way. The Huf are a hair smaller on the neck I know that and will fit more then the Genuine , Almost fit the R90's we have on super sale , but sold out , as people were asking about these. Don't have any R83's here in stock otherwise I could mount one for you. Post up what you find out.
Old Mar 15, 2016 | 09:11 AM
GimmeBoost's Avatar
GimmeBoost
Dropped off one wheel/tire and a new Huf sensor with my tire guy this morning. He just called and said there's two small bosses inside the wheel that prevent the sensor from sitting flush as it needs to. I'm going to take a look when I go to pick it up, grab a picture if I can.
In any case it looks like the Gen1 r83 style wheels are a no go for a TPMS retrofit.
Old Mar 15, 2016 | 09:15 AM
Thanks for the update, yes, get a pic, huf genuine MINI or huf orange ?
Old Mar 15, 2016 | 10:28 AM
GimmeBoost's Avatar
GimmeBoost
Huf orange. The gap you see there simply isn't big to insert the TPMS.
Old Mar 15, 2016 | 10:50 AM
GimmeBoost's Avatar
GimmeBoost
Wow this site stinks on mobile. Posting doesn't work on the first try, inserting pictures doesn't work at all, and neither does editing a post apparently.
In any case, here's the picture of the inside of the wheel. The gap is just too narrow to get the TPMS into.
Last edited by GimmeBoost; Mar 15, 2016 at 10:54 AM. Reason: Sorry, that first picture was ginormous.
Old Mar 15, 2016 | 10:53 AM
Thanks, did the outside of the barrel get shaved at all, was it close and could be shaved?
Old Mar 15, 2016 | 10:56 AM
GimmeBoost's Avatar
GimmeBoost
It would need to be shaved quite a bit. I'm not keen on doing that sort of thing to begin with so I didn't look real close. Sorry.
Old Mar 15, 2016 | 01:53 PM
hsautocrosser's Avatar
hsautocrosser
R83's were fitted with TPMS sensors from TireRack in this thread from Feb. 19th.
https://www.northamericanmotoring.co...ich-style.html
Old Mar 15, 2016 | 02:04 PM
I remember on some OEM MINI wheels in ~2007 there was some part number updated, might have been to change the wheel design to accept more TPMS sensors of the newer MINI, late in 2007 MINI introduced the mandatory TPMS in board sensors. ( For MINI without a spare wheel , or spare wheel and running runflats.
This might be the issue , older part number wheels
Old Mar 15, 2016 | 02:05 PM
GimmeBoost's Avatar
GimmeBoost
Well that's stange. ECS says the Huf orange sensors are smaller and more likely to fit, but that poster says the OEM sensors are the ones that fit.
ECS, is the body on the OE type sensor more able to fit into that small recess? Better pictures of the wheel are available in the thread here: https://www.northamericanmotoring.co...lve-stems.html
Old Mar 15, 2016 | 02:13 PM
Yea, I think its was an OEM sensor on a newer part number wheel, in 2007 MINI changed part numbers on allot of gen 1 OEM wheels . We compared the bodies and the huf orange is smaller and little bit less broad on the shoulder to the head of the valve, thus should be able to fit more. Whats the part number on your OEM wheel, it might have the 7 seven digits or 5 digits stamped into the barrel or on the back wheel spoke, or near the back where it meets the hub. Take some pics , post up..... we will get to bottom of this strange and only 5 people know in the world questions.
Old Mar 16, 2016 | 05:38 PM
GimmeBoost's Avatar
GimmeBoost
Wheels aren't at my primary residence, so it was tough to get pictures, but this is what I've got. The first one is (I think) what the wheel is made from. The second and third don't look much like BMW part numbers as they're too short, but it's the best source I found. There is what appears to be a date stamp on the wheel though, and I think indicates that they were made in 2002. So if there's a revised version, these probably aren't them.
Yes, they need a cleaning.
Old Mar 17, 2016 | 05:20 AM
Thanks for that.
Yes, the parts numbers for this one did not change , but yes , its older and most likely way before the tpms re design.
