R56 HELP!!!! mini wont start - battery good, was literally just running at lunch!!
Old Dec 9, 2015 | 12:58 PM
escriba's Avatar
escriba
hey, this just happened to me, i just owned the car for a week.
i drove it at lunch, parked it.
went down for a smoke and was going to get a coffee and i go to start it and it makes one click, like it wants to start and then nothing.
i also noticed that the driver side window is not doing the roll down/roll up when the door opens, but the passenger side does.
it gave me an exclamation mark on the warning light that the book says is driver door open while ignition on? pg 39 on owners manual
i need to move the car, please help me out
Old Dec 9, 2015 | 05:52 PM
AZdsrt's Avatar
AZdsrt
Year and model will help with responses. How do you know the battery is good? A marginal battery on these cars cause all kinds of problems, including what you are describing..
Old Dec 10, 2015 | 09:35 AM
escriba's Avatar
escriba
ok so i went to boost the car as people suggested dead battery and i found out the negative terminal was not tightened and it had almost completely come off.... i called and b!tched the dealer out for their shoddy workmanship and got a credit for the labour amount to replace battery.
Old Dec 10, 2015 | 09:38 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Now that it's running again, is it still having those other issues? Be sure to test the battery. If it's going bad you could have this issue again.
888.280.7799 | 6am - 5pm PST
Old Dec 10, 2015 | 12:39 PM
That's crazy, it has a little nut that presses up, if the put the terminal on really quick it will hand on the post, you have to push it down on the terminal all the way loose then tighten it up.
Benibiker
Nov 8, 2020 03:07 PM
themarques
Mar 29, 2018 11:55 AM
morphix
R60/R61 Stock Problems/Issues
Nov 21, 2015 02:22 PM
Nick Webb
R55 :: Clubman Talk (2008+)
Nov 16, 2015 11:32 AM
Colt45Magnus
Nov 12, 2015 06:47 AM
