Navigation & Audio Let's see your GPS/portable nav mount!
Old Dec 4, 2015 | 03:11 PM
bctf1's Avatar
bctf1
So you didn't get the factory navigation when you got your Mini, well I didn't either. I just figured that I would just use my phone. Now I have changed my mind and want to add a portable GPS (looking at a Nuvi 2589LMT FWIW) to my F56. I think I'm aware of most of the mounts that are out there, but you never know.
I don't care whether you have a Classic Mini, R53, R56, F56 or any other model and I don't so much care which GPS you might have. I want to see pics of your GPS mount for mounting ideas. Please identify the mount you have along with the pics.
Old Dec 4, 2015 | 04:58 PM
vetsvette's Avatar
vetsvette
Moderator
Cravenspeed with Garmin 2497LMT. Same setup I had in my R56. I've never been a big fan of factory nav systems.
F56
R56
Old Dec 4, 2015 | 06:49 PM
TWISTER's Avatar
TWISTER
Proclip.com so your view is unubstructed and almost hidden from thieves
Old Dec 4, 2015 | 08:36 PM
bctf1's Avatar
bctf1
I am aware of the proclip mount for my F56. Do you have one installed? If so, got pics?
Old Dec 4, 2015 | 08:38 PM
bctf1's Avatar
bctf1
F56
Thanks vetsvette for your post and the photos.
Old Dec 6, 2015 | 10:08 AM
TVPostSound's Avatar
TVPostSound
Garmin 2597LMT
Went with the Craven Speed mount. Eyes on the road at all times.
Here's what I first had, Proclip was dangerous looking down all the time.
Old Dec 7, 2015 | 05:33 AM
hammerhands's Avatar
hammerhands
Usually I have my iPod in the MINI Click & Drive, but it was made to use with a Garmin Nuvi, 310 or 360? Here is my Garmin Nuvi 550. Sure wish it was an LM version.
It has its own USB port to power the GPS.
Attached Thumbnails Let's see your GPS/portable nav mount!-image.jpeg
Old Dec 7, 2015 | 05:35 AM
hammerhands
A picture of a Garmin MINI sells.
I've got a Dual XGPS150 [A maybe?] Bluetooth GPS I use with my iPod, but it never seems to be charged.
http://gps.dualav.com/explore-by-product/xgps150a/
Old Dec 7, 2015 | 10:10 AM
bctf1's Avatar
bctf1
My decision has been made. I am going with the combination of the Nuvi 2589LMT (5" screen, Voice Navigation, Bluetooth and Lifetime Maps)and the Mini Click and Drive Mount. I just hope that the dealership doesn't gouge me too bad on the Click and Drive installation. This will give me the cleanest install of all available options with no visible wiring to deal with at all.
Thanks to everyone who participated in this thread.
Old Dec 7, 2015 | 01:08 PM
DaGriz's Avatar
DaGriz
I'm still going to stick with my IPhone using the Koomus Pro mount. I can't see paying for something I already carry in my pocket.
Old Dec 7, 2015 | 02:05 PM
hammerhands
I can see where the USB plugs into the Click & Drive!
Be sure to get a Garmin ball mount for your iPhone.
The 2589lm should mount on the Clck & Drive's ball similarly to this, that ball mount adapter ought to be included with the 2589lm, so you shouldn't need any other hardware.
Old Dec 15, 2015 | 07:21 PM
bctf1's Avatar
bctf1
I have an appointment to have the click and drive installed at the dealership on my F56 on Monday and I will mount a Nuvi 2589LMT GPS to it. It is unclear to me looking at the Click and Drive install instructions if the wiring harness is to be connected to an "always on" circuit on the fuse panel or if it is a circuit that will power on and off when the car is started and shut off.
I have been using the Nuvi with it's included power adapter connected to the 12v accessory plug on my console which is not on an always on circuit. The Nuvi will power up when I open the car door and it will power off after a few minutes after shutting the car off. That means that the GPS will power up every time I get in the car even if I don't plan to use it. I am wondering if it would be better to connect the Click and Drive's wiring harness to an always on circuit instead.
I would appreciate input on that question and also clarification from the attached install guide which type of circuit it specifies for the install.
https://dl.dropboxusercontent.com/u/...nd%20Drive.pdf
Old Dec 16, 2015 | 11:47 AM
hammerhands
My dealer did the install, I assume per instructions, and it powers off with the car.
Are there always on circuits?
You can get a back camera for some Garmins!
Old Dec 16, 2015 | 12:14 PM
bctf1's Avatar
bctf1
Thanks for your reply. Out of curiosity, what did he charge you?
Old Dec 17, 2015 | 05:00 PM
hammerhands
$100 Canadian, when it was more or less on par with the U.S. dollar.
The instructions say 0.75 hrs.
Old Dec 23, 2015 | 01:28 PM
The click and drive actually looks pretty good.
Old Mar 18, 2017 | 07:51 PM
miniuy's Avatar
miniuy
I bought the official mounting kit and the Garmin Nuvi 2497.
I want the MINI splash screen on my Nuvi but it seems the splash screen change on this model is not easy (as in older/other Garmin models where you could replace or create an image and paste it to the GPS directory).
Any advice on this?
Old Mar 26, 2017 | 09:27 AM
Zazoh's Avatar
Zazoh
CravenSpeed ...
Old Mar 26, 2017 | 03:40 PM
umberto's Avatar
umberto
I positioned my garmin nuvi down below the toggles and with double stick tape fastened four little appliance rubber feet from a hardware store and the garmin snaps in, or out ....and the model i chose allows it to be synced with the BC-30 back up camera ...works quite nicely l
i posted the pictures here on a different thread, on posts # 43 and #43
https://www.northamericanmotoring.co...e-worst-2.html
nutsofamily
Jan 16, 2016 03:08 PM
GrabPatch
Nov 19, 2015 04:15 PM
Apexx
Nov 9, 2015 08:07 PM
WhinyR53
Nov 9, 2015 09:13 AM
