R52 R52/53 wheel arch trim
Old Nov 29, 2015 | 04:04 PM
davavd's Avatar
davavd
Does anybody know if I need any additional parts when replacing rear wheel arch trim on a 2006 S?
Old Nov 29, 2015 | 04:09 PM
MINIAC's Avatar
MINIAC
Depends if you need any clips ...
RealOEM - R52 Cooper S Exterior Trim
Old Nov 29, 2015 | 04:17 PM
davavd's Avatar
davavd
How do I know if I need any clips?
Old Nov 29, 2015 | 04:47 PM
MINIAC's Avatar
MINIAC
You'll need to replace any that get broken removing the trim piece being replaced.
Old Nov 29, 2015 | 09:47 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Our new trims come with the clips on them already.
http://www.waymotorworks.com/wheel-a...52-cabrio.html
Old Nov 30, 2015 | 05:49 AM
davavd's Avatar
davavd
Well, since I ordered it from you, I should be fine!
Old Nov 30, 2015 | 01:52 PM
jgk6502's Avatar
jgk6502
The clips seem pretty standard across all cars. In case you break one, I've seen them at local auto part stores
Old Dec 2, 2015 | 05:29 AM
They come with the clips, the only thing they might need is that little nut on the front cover , it screws into the end. If you still have it on the old one or have it from the old one your ok then. 51131505867 51131505866 51131505865 51131505864 51131505869 51131505868
https://www.northamericanmotoring.co...el-arches.html
07130702715
Our trim tools make it easier to take these off.
Old Dec 8, 2015 | 06:02 AM
davavd's Avatar
davavd
The part is here
This looks pretty straightforward; all the bits seem to match up. Any advice from anyone who has done this?
Old Dec 8, 2015 | 06:07 AM
Yep thats it , bend its al little and insert the tab into the rocker sill and the rear arch first then push in and snap on.
Old Dec 9, 2015 | 08:30 PM
WayMotorWorks
Vendor
Thanks we appreciate it
happychap
Feb 8, 2018 10:19 AM
IceRafter
Dec 22, 2015 04:00 AM
jideonu86
Tires, Wheels, & Brakes
Nov 16, 2015 05:07 AM
coogamoogakid
Nov 9, 2015 02:36 PM
AvianMan
Nov 3, 2015 11:00 AM
