R50/53 Oil leak update - ugh. How much is too much?
Old Nov 25, 2015 | 03:29 PM
elite2000's Avatar
elite2000
So I took the dumb car in, 06 r53. Was told it was the crank position sensor o-ring. Then I get a call its the oil pan also. I didn't have time or money so I picked up the car. Then took it back and was told it was the oil pan as well as the rear main seal. I'm annoyed, I found a place that'll do it all and a clutch kit but at the moment the car shifts fine. Will the world end of I just keep adding oil as needed? Obviously oil can eventually get into the clutch and it'll need to be replaced anyway but for now, can I drive a few 1000 miles through the winter? Lastly is there a low oil inticator or do I just check it weekly/biweekly? The spot from the drive is attached. Advice?
Old Nov 25, 2015 | 03:51 PM
bavmotors's Avatar
bavmotors
No low oil indicator only low pressure, I'd keep an eye on the level. Rear main is a bummer not a real common spot from what I've seen, as for the oil pan and crank seal that's almost a given.
elite2000's Avatar
elite2000
I would der if my shop simply doesn't know how to properly diagnose the problem. Hmmmm
Old Nov 25, 2015 | 03:55 PM
bavmotors's Avatar
bavmotors
well you could always get a second opinion to be sure since that's an expensive fix.
Old Nov 25, 2015 | 04:02 PM
Shawnnn's Avatar
Shawnnn
Absolutely drive it. It doesn't matter if it's leaking as long as you keep an eye on it.
It would be a bad idea to wait for the oil light to come on though. You don't want to ever drive it without oil. I would check it at least once a week just to be safe. Maybe every 2 weeks if it's going down slowly.
As far as the clutch, you should get some warning first that it's slipping. Mine started slipping on the freeway in sixth gear, just a little, then gradually over a year it got worse. Still very drivable, just didn't like hard acceleration in any gear at the end. Like I said though, took a year to get there.
Fix it when you have the time and money though, because it will get worse over time
Old Nov 25, 2015 | 04:04 PM
Shawnnn's Avatar
Shawnnn
My rear main seal was a little wet when I did my clutch. If you watch the mod mini clutch how to video, the car he did had a really bad rear main
Old Nov 25, 2015 | 07:37 PM
elite2000's Avatar
elite2000
Agree....I think I'm just going to drive it and watch it. I gotta put down something in the garage but ya.....eff it until spring ;-).
robotrock
Nov 11, 2015 09:29 AM
ezmesican
Nov 9, 2015 08:51 PM
ionphoenix
Nov 9, 2015 01:33 PM
AoxoMoxoA
Nov 4, 2015 06:32 AM
AvianMan
Nov 3, 2015 11:00 AM
