R50/53 FLywheel bolt pattern/circle ?
Old Nov 18, 2015 | 04:11 PM
got_mini?'s Avatar
got_mini?
Does anyone have this spec ?
or at bare minimum measure it for me ?
I believe they are the same but for an MCS (R53)
Old Nov 27, 2015 | 04:06 PM
got_mini?'s Avatar
got_mini?
anyone able to measure this or know the measurement ?
THANKS
Old Nov 27, 2015 | 04:17 PM
Kahnfucious's Avatar
Kahnfucious
Originally Posted by got_mini?
anyone able to measure this or know the measurement ? THANKS
Not sure what you are asking for - and not many people have access to their flywheel to measure anything on it...
What are you trying to figure out?
Old Nov 27, 2015 | 04:52 PM
got_mini?'s Avatar
got_mini?
Well i know the flywheel has 8 bolts, so the measurement would be from center of one bolt straight through the center of the flywheel to the center of the adjacent bolt hole.
i need this measurement for a possible rwd project where i wont be using the MCS flywheel, so i need to be able to have my machine shop drill this bolt pattern on a different flywheel.
Old Nov 27, 2015 | 05:29 PM
Kahnfucious
Well i know the flywheel has 8 bolts, so the measurement would be from center of one bolt straight through the center of the flywheel to the center of the adjacent bolt hole. i need this measurement for a possible rwd project where i wont be using the MCS flywheel, so i need to be able to have my machine shop drill this bolt pattern on a different flywheel.
Yeah - wish I could help but again my flywheel is nicely tucked away behind my transmission. Maybe one of the vendors/forum sponsors might be willing to do you a solid. Given the cost of machining what you want though - I would be really hesitant with just measurements from someone on a forum. Check eBay - used flywheels all over the place
Old Nov 27, 2015 | 07:33 PM
got_mini?'s Avatar
got_mini?
I understand what ya mean by trusting but for know just an approximation would help me to know if my plan will work, or if i need to go another route.
Old Nov 27, 2015 | 10:17 PM
Filmy's Avatar
Filmy
IIRC, the crank/flywheel holes are not uniform. That is, the holes only line up one specific way. So if you're thinking of turning and drilling your own part, you'd best get a flywheel or crank to use as a template.
Old Nov 28, 2015 | 10:38 AM
Shawnnn's Avatar
Shawnnn
I have my old flywheel in the garage so I can give some inexact measurements with my tape measure.
Filmy is correct though, the holes aren't uniform.
Old Nov 28, 2015 | 10:58 AM
Shawnnn's Avatar
Shawnnn
Heres a picture
Attached Thumbnails FLywheel bolt pattern/circle ?-20151128_123149-1200x2134.jpg
Rennfahrer555
General Discussion
248
Apr 25, 2016 12:49 PM
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
Aerobrew9
Oct 20, 2015 04:44 AM
Aerobrew9
Oct 18, 2015 05:27 PM
genik
Oct 18, 2015 11:41 AM
