R50/53 R53 convert to NA high compression pistons ?
Old Nov 17, 2015 | 06:49 AM
got_mini?'s Avatar
got_mini?
Does anyone know of somewhere tha has or makes high compression pistons for the R53
Im assuming custom is what ill have to look at
Old Nov 17, 2015 | 07:02 AM
Helix13mini's Avatar
Helix13mini
That might not be that good of an idea. If you're looking to get more performance out of the car, there are a number of tried and true methods. Even if you're planning to run race gas, your performance gains will not be what they could be with other tuning tricks.
Old Nov 17, 2015 | 08:21 AM
Saltysalt's Avatar
Saltysalt
are you keeping the S/C? otherwise I would strongly not consider high comp pistons. if you remove the S/C then yea sure. unless you are willing to run w/m all the time
Old Nov 17, 2015 | 08:27 AM
got_mini?'s Avatar
got_mini?
ya no supercharger
i found out that RMW makes custom pistons, waiting to hear back from them
Old Nov 17, 2015 | 09:56 AM
Saltysalt's Avatar
Saltysalt
yeah im not sure if he actually makes them or not, but he would be a good source. since you are not running with the S/C and have 93 octane available to you, you should be able to run 12.5:1 easily. although the pistons may have to be cutback for the valves as well
Old Nov 20, 2015 | 10:35 AM
IQRaceworks's Avatar
IQRaceworks
Originally Posted by got_mini?
ya no supercharger
I would think that in order to make as much as a supercharged R53, if you went N/A....you are going to have a motor that isn't nearly as streetable (race fuel, huge cam, no low end power)......why wouldn't you keep the SC?
patsum
Dec 30, 2015 06:48 AM
Racingguy04
Off-Topic :: Autos
Nov 19, 2015 11:37 AM
got_mini?
Nov 17, 2015 02:00 PM
pahg
Nov 11, 2015 02:03 PM
Emnotek
Nov 11, 2015 12:35 PM
