R50/53 Mystery bolts and washers
Old Nov 16, 2015 | 02:06 PM
rocklinbrad's Avatar
rocklinbrad
So I recently replaced a few parts on my car (oil pan gasket, cv boot, control arm bushing, upper motor mount and lower motor mount) and ran into a bit of a problem while putting it back together.
I have these two 10mm bolts/screws and their odd washers. I have no idea as to where they go. If anyone knows the location or has ideas or help it would be very appreciated.
Old Nov 16, 2015 | 02:09 PM
Wertles's Avatar
Wertles
Did you put the car in service mode? Those look like they are the bolts and plastic washers that help line up the radiator support and bumper. I didn't remove those when I did the work on my car.
Old Nov 16, 2015 | 03:52 PM
jc130chief's Avatar
jc130chief
Pictures, always take lots and lots of pictures when doing projects.
Old Nov 16, 2015 | 03:56 PM
Kahnfucious's Avatar
Kahnfucious
I agree those go on the front of the car - helps line up the metal bumper.
Old Nov 16, 2015 | 08:33 PM
rocklinbrad
Wertles and kahnfucious you are both correct, that is exactly where they go. Thank you! Jc130chief thank you also.
Old Nov 17, 2015 | 05:54 AM
Alignment screws and washer , correct. Those two are right on point.
Old Nov 17, 2015 | 07:08 AM
Helix13mini's Avatar
Helix13mini
When re-installing them, install them finger tight until you align bolt the radiator support and bumper support. Otherwise you'll have a hell of a time getting everything to fit together: basically, you want those bushings to move a little as you install the other bits.
hamptup
Oct 23, 2016 09:06 PM
silence2-38554
Oct 7, 2015 10:59 PM
bavmotors
Oct 7, 2015 09:17 AM
GoBadges
Oct 1, 2015 11:10 AM
Nicefeet
Sep 27, 2015 11:14 AM
