R50/53 Need help (lower steering shaft)
Old Nov 14, 2015 | 05:46 PM
takrdown's Avatar
takrdown
Guys, I just installed a new lower steering shaft and it was definitely my steering problem so I'm happy about that. I created a self induced problem though: when I took off the old steering shaft the wheels were straight and the steering wheel was straight. Not so much anymore.
When I Installed the new steering shaft I must have bumped something and now the car is straight with the steering wheel half over to the right.
Does anyone have any easy recommendations to right this? I'm going to drive it up on rhino ramps tomorrow with the wheels straight and then straighten the steering wheel once I uninstall the shaft and then reinstall. Not sure that'll work though.
Old Nov 14, 2015 | 06:12 PM
Nicefeet's Avatar
Nicefeet
I suggest clicking this link:
http://www.detroittuned.com/content/...g%20Repair.pdf
Old Nov 14, 2015 | 06:16 PM
takrdown's Avatar
takrdown
I just found this as well thanks! Is this common? Difficult? Thanks!
Old Nov 14, 2015 | 06:19 PM
Nicefeet's Avatar
Nicefeet
You'll need to find someone with the proper scan tool to reset the steering angle sensor. If not the traction control light will come on.
takrdown's Avatar
takrdown
Wait so I'm just pulling the airbag and making a new "straight" on the steering wheel? That's too easy if I'm reading it right.
Old Nov 14, 2015 | 06:22 PM
Nicefeet's Avatar
Nicefeet
If you have DSC you'll need to reset the steering angle sensor.
Old Nov 14, 2015 | 06:44 PM
takrdown's Avatar
takrdown
Same procedure as a BMW? Rack it full left to full right a few times?
Old Nov 15, 2015 | 07:29 AM
takrdown's Avatar
takrdown
Anyone know how to find Repair Instruction 6131006 that it refers to in the Detroit Tuned procedure post above? It is "Remove and refit bracket for steering column switch."
Thanks!
Old Nov 15, 2015 | 08:51 AM
Nicefeet's Avatar
Nicefeet
There's no reason really to tear into that far. Just move the steering wheel over 7 splines and call it a day.
I think the only reason they reference those instructions is if you really screw something up.
Old Nov 15, 2015 | 09:49 AM
takrdown's Avatar
takrdown
Great thanks! It's all buttoned up and I'm taking it to my Indy shop to reset the steering sensor tomorrow. It was more like 10 spindles so I hope it works ok. I readjusted it 4 or 5 times until it was straight and true going down the road.
Old Nov 15, 2015 | 10:21 AM
Nicefeet's Avatar
Nicefeet
Did your tire and dsc light come on?
Old Nov 15, 2015 | 01:35 PM
takrdown's Avatar
takrdown
They both did which is expected I would think with an adjustment to the steering wheel by that much
Deej Ledingham
Dec 21, 2015 01:33 PM
jrs66
Oct 24, 2015 09:34 AM
Odin2free
Oct 19, 2015 02:11 PM
jonnieh123
Oct 16, 2015 02:55 PM
