R56 Who has the best price on Koni FSD
Old Nov 14, 2015 | 01:25 PM
Kingerbeerman's Avatar
Kingerbeerman
Looking to upgrade my wife's 08 MCS.
Just curious where the best price may be for Koni FSD's and how big of a job it is.
Cheers
Andrew
Old Nov 14, 2015 | 01:40 PM
Greeny's Avatar
Greeny
I'm looking to get some in the spring. This is the cheapest I've found.
http://www.motoringwerks.com/p-3675-...sd-shocks.aspx
Wish I could give more info with the install as far as tips. I do know you need a spring compressor which can be rented from most auto parts stores.
Old Nov 14, 2015 | 02:26 PM
oldbrokenwind's Avatar
oldbrokenwind
When I was shopping, I found Tire rack had the best prices. This was when Koni was having a "nation-wide" sale too --- most dealers had "sale" prices.
You need a "special tool" to keep the shock from turning when loosening - tightening the top mounting nut. This Koni nut was a different size from OEM on my '07 MCS. I used a socket with an open end wrench for the nut and a hex wrench thru the socket wrench opening to keep the shaft from turning.
And, be careful with what kind of spring compressor you get --- the multiple, (3-piece) version can be dangerous to use on our short springs.
When you're all done with shocks, it's highly recommended you get a wheel alignment. You can get it back together pretty close, but I wouldn't put too many miles on it without an alignment.
Old Nov 14, 2015 | 05:08 PM
sgscomps's Avatar
sgscomps
NM Engineering has them for $691.12 http://www.nm-eng.com/231/2/0/1472/2...shock-kit.html Jerry has great customer support too.
Old Nov 14, 2015 | 06:13 PM
Kingerbeerman
Thanks !!!
Shocks are beat and want a more comfortable ride, have low profile 18's on the car now and it looks awesome but beats you up!!
Old Nov 14, 2015 | 08:38 PM
Fly'n Brick's Avatar
Fly'n Brick
Consider changing the rear sway bar to an adjustable 19 or 22 MM. The difference in handling is unbelievable and the FSDs go right a long. Easy to add while the rear member is broken down for the strut install.
Old Nov 15, 2015 | 08:13 PM
daddyandmadi's Avatar
daddyandmadi
I got mine from out motoring for $600 early this summer. They have a 5% off code if you subscribe to their email too. Shop around because sales prices go on all the time
Old Nov 17, 2015 | 09:14 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
We will be having a significant discount on Koni's for Black Friday/Cyber Monday. It will be a spring/strut kit though.
888.280.7799 | 6am - 5pm PST
Old Nov 18, 2015 | 05:05 PM
richardsperry's Avatar
richardsperry
My friend Vic is selling a very slightly used set in the classifieds... Just saying, they are almost new, I'll even toss in the rear spring hats pre drilled to accept the koni's. If you're close to us, I'll install them for you for free too...
Old Nov 22, 2015 | 07:57 AM
Kinger's Avatar
Kinger
Wow I wish I lived close by...I would take you up on that offer, long drive from New Brunswick Canada.
CheersAndrew
Old Nov 24, 2015 | 08:39 AM
Kinger's Avatar
Kinger
Ok
2008 Mini Cooper S
What's your price?
Old Nov 30, 2015 | 08:50 AM
PelicanParts.com
Vendor
We have the Koni Sport Suspension Kit with H&R Springs with 25% off HERE. Offer ends tomorrow.
cmutt
Navigation/Audio
Jun 10, 2020 10:01 PM
mynamesconnor
Sep 18, 2017 09:48 AM
toddtce
Jan 14, 2016 08:14 AM
scoopy
Nov 1, 2015 06:00 PM
scoopy
Suspension
Oct 30, 2015 12:27 AM
