R56 Evap codes r56 justa help
Old Nov 14, 2015 | 08:29 AM
Saltysalt's Avatar
Saltysalt
Hey fellas. Im ussually in the r53 section. But the GF has a r56 justa and has thrown 2 codes. P0442 and the other code was lean condition found upon start up. P2097. Im not sure if the p2097 has come back or not. But p0442 has the gas cap warning periodically during trips. We have tried putting the gas cap on multiple ways. Theres no visual damage to that. After doing some research there is the dmtl pump and the charcol canister. Would eith of these be affected with this code?
One piece of info is that when ever we put gas in the mini it wont start under normal idle throttle. We have to full throttle for it to start. This is only after putting gas in the car.
Any ideas on where i should start looking?
Old Nov 15, 2015 | 04:57 PM
Saltysalt's Avatar
Saltysalt
bump for help
Old Nov 16, 2015 | 11:13 AM
Tio Barry's Avatar
Tio Barry
Do a search for gas cap in 'stock problems'. There is previous discussion there.
Old Nov 16, 2015 | 11:20 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
New gas cap first, as it is cheap and can solve the issue.
Old Nov 16, 2015 | 01:44 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
P0442 - Solutions here. If the seal is bad on the cap, it can trigger this. It's the easiest/cheapest place to start. Gas cap here if needed.
P2097 - Few possibilities - Post Catalyst Fuel Trim System Too Rich (Bank 1) or Pre-catalytic oxygen sensor, mixture fine-tuning: Exhaust gas behind catalytic converter too rich. Possible solutions Here.
888.280.7799 | 6am - 5pm PST
Old Nov 17, 2015 | 03:21 PM
Saltysalt's Avatar
Saltysalt
thank you fellas, ill try stock problems real quick, and try and get a new gas cap, although i have my doubts
Old Nov 17, 2015 | 03:40 PM
Minnie.the.Moocher
Keep in mind that the new gas cap doesn't always immediately fix the issue. The evaporate system check gets triggered after a certain set of parameters gets met. In my case it went away after a few drives and over 100 miles.
Old Nov 19, 2015 | 12:28 PM
Saltysalt's Avatar
Saltysalt
well for the first time yesterday, gas was put into the car much more easily. and started normally. which could be a number of things,
1.) colder so the tubing for the evap system is better sealed
2.) gas cap had a better seal
3.) gas cap was put on a different way
Old Nov 19, 2015 | 12:38 PM
nkfry's Avatar
nkfry
There are 3 renditions of P2097, and you will only know which of the three you are currently dealing with is to find someone with a dealer level tech tool.
1. Post catalyst fuel trim system too rich
2. Pre catalyst oxygen sensor, mixture fine tuning: exhaust gas behind cat too rich.
3. Pre catalyst oxygen sensor, system check: Signal stuck lean.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
JamesDeBart
Apr 16, 2016 05:00 PM
Alpha Motoring
Nov 10, 2015 07:08 AM
Emnotek
Oct 2, 2015 08:43 AM
racer_tom
Oct 1, 2015 05:25 PM
WhinyR53
Sep 30, 2015 07:36 AM
