R50/53 New owner needing help
Old Nov 13, 2015 | 09:06 AM
Jeff Nyquist's Avatar
Jeff Nyquist
Hello all!
I recently became the new caretaker of a Hyper Blue 2006 MCS with 40k miles. It appears to have a few mods that I'll need to disclose up front to hopefully help diagnose my issue.
The mods that I can see/easily verify are: DDMWorks Intake, 15% pulley, and Supersprint catback. I haven't put the car up on a lift, so I have not verified the header. Suspension (although no relevant to the issue) is still all labeled Mini so appears to be stock.
The car is extremely clean and looks to have been pretty well cared for, outside of a couple of areas on the bonnet where it looks like someone used a dirty rag to 'clean' and scratched up the clear coat. Already attacked that with good polish and my Porter Cable 7424XP and that's shaping up pretty good.
With all of that said, the car exhibits some seemingly common yo-yo effect at around 3k ... quick stuttering of power from maybe 2800 - 3200, and then perfect above that. I figured I would eventually get around to sorting that out, and it wasn't much of a concern.
Today however, I was making a left hand turn (let's say 3rd gear because I did not need to stop to make the turn) and was aggressive with the throttle after the apex. At what I think was similar rpm's, the car just completely stopped accelerating and had zero power... no CEL, no indication anything was wrong, no weird noises, just absolute bog. I downshifted to 2nd and feathered the throttle a bit, and within a few seconds, the car was back to normal although seemingly not from anything I did.
Fast forward about 7 miles, and I was accelerating onto an onramp and had almost the exact same thing happen.
My first guess is an issue with the bypass valve. Given the other mods, I need to check if the one installed is stock or not. Does the Detroit Tuned one have anything visible from the outside that is different from stock?
My second guess is a fuel starvation issue. I was slightly below a quarter tank when this happened. Any known issues like this? I don't think I've run the car that low before, so I went to the Mobil station and filled up with premium.
Any help would be appreciated. This has been a fun car so far!
Thanks,
Jeff
Old Nov 13, 2015 | 09:11 AM
bavmotors's Avatar
bavmotors
Detroit tuned valve will appear the same, did you perhaps lose traction?
Old Nov 13, 2015 | 09:23 AM
Jeff Nyquist
Definitely not a loss of traction... with these mods, that's easy to do and I'm familiar with what that feels like on this car. UNLESS somehow there was intervention from a nanny that thought I was crashing and took drastic measures? But most certainly in the second case, all wheels were pointed the same direction (or within a few degrees).
Old Nov 13, 2015 | 12:07 PM
pikwit's Avatar
pikwit
If it was nanny intervention, your traction control light will flash. I've got similar mods and with traction control on, it'll cut the fun short pretty hard in first or second. I had a pretty bad loss of power in the same RPM range as you and a new coil pack, plugs, and wires solved my issue.
Old Nov 13, 2015 | 12:46 PM
Yea the DCS light or traction light would have popped up very quickly. If its not the BPV , you can check the coil pack for corrosion on the terminals. The terminals can corrode and cause some issues. When was the last time the coils and plugs were done.
Old Nov 13, 2015 | 01:04 PM
blankie's Avatar
blankie
I had the exact same issue, it was my fuel pump. every couple of minutes, it would act as if it died, no cels, all other electricals stayed on, after a few peddle presses later, it would kick back on like no problem.
Old Nov 13, 2015 | 03:26 PM
Jeff Nyquist
Since the car only has 40k miles, I assume the plugs, wires, and coilpack are original. Under the hood, everything is extremely clean with no visible corrosion anywhere. I was planning to do plugs and wires anyway, so I guess I'll add in the coil pack for good measure.
I'll have to look up the DIY on the fuel pump. Without research, I'm hoping it's not one that is in the tank....
-Jeff
Old Nov 13, 2015 | 03:43 PM
blankie's Avatar
blankie
its under the back seat, on the driver side access hole. extremely easy to get to. all together with gathering tools, and putting tools away I think I did the fuel pump and the fuel filter in about an hour.
blankie's Avatar
blankie
you also might want to look into the recalls, I think the 05-06 mcs had a high pressure fuel pump (hpfp) and they had issues.
Old Nov 14, 2015 | 08:05 AM
bavmotors's Avatar
bavmotors
no hpfp on the r53 as far as I know.
Old Nov 14, 2015 | 09:28 AM
Jeff Nyquist
Right, no HPFP on the R53. Sounds like the fuel pump replacement is straightforward. I did the sparkplugs and wires last night which had no effect on the yo yo at 2800-3200, however I have not had a recurrence of the complete loss of power for multiple seconds yet.
If it happens again, I'm leaning more towards the fuel pump rather than the coil pack....
-Jeff
Old Nov 16, 2015 | 12:56 PM
Here is the fuel Pump : 16146765121 It comes with the pump in-cased in a module housing and neck, also includes the one side fuel level sensor. ( Two level sensors in the tank. )
https://www.ecstuning.com/Search/SiteSearch/16146765121/
Old Nov 19, 2015 | 08:14 AM
Jeff Nyquist
Quick update
So it's been a number of days since the last time I had the complete power loss issue. Today however, I took a 90 degree left turn at a good clip and lost power, and reflecting back to both other times this happened, it was immediately after a left turn. Does this sound like a failing fuel pump? Or something w/ the fuel pick up?
I guess I should at a minimum take the pump out and look at it....
-Jeff
Old Nov 19, 2015 | 08:19 AM
I would take it out and see if there is dirt or something in the pickup. Has the pump been changed or wires messed with.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
Alpha Motoring
Nov 10, 2015 07:08 AM
newminijcw
Oct 21, 2015 02:37 PM
barthayes
Oct 1, 2015 05:22 PM
TBRoye
Sep 29, 2015 06:49 AM
