R56 Headlight washer jets
Old Nov 11, 2015 | 04:39 AM
Flyinace2000's Avatar
Flyinace2000
My 2007/2009 had washer jets that would fire at the headlights when you cleaned your windshield. My 2011 does do it and i figured it wasn't equiped, but i was poking around yesterday and noticed that it does have the washer there. Did the process change with the N18 update or did all the cars get the hardware and it needs coding to work? Or is it just broken and i should use my extended warrant (if it covers it).
Old Nov 11, 2015 | 12:55 PM
For a brief year, they came with headlight washers but the wires and tubing are not there. Then they came back, it was a weird thing maybe with production or supplier.
Old Nov 11, 2015 | 02:58 PM
Flyinace2000
I'm pretty sure I have the washers and i saw tubing/wiring going to/from it. I'll confirm in the morning and post some photos.
Lets assume its all there and hooked up, why wouldn't they be firing?
Old Nov 11, 2015 | 08:19 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
For my 2012 the headlight washers were an option (I declined.) The headlight assembly has the the washer sprayers but the extra pump, wiring, and tubing was optional. IIRC you can see the optional stuff on realoem.com.
Old Nov 11, 2015 | 08:38 PM
renchjeep's Avatar
renchjeep
I thought the headlight washers were only on factory-equipped Xenon cars, or whatever the upgrade from regular halogens was called? If you have factory Xenons, you should have the headlight washer jets.
Old Nov 11, 2015 | 11:07 PM
squawSkiBum
Moderator
With xenon headlights (option code S522A) the headlight assembly includes the washer jets, the pump and plumbing (option code S502A) is separate. At least for my model year. see here: http://www.realoem.com/bmw/enUS/show...diagId=61_2184
polibureau
Sep 9, 2016 08:44 AM
luisfv56
Dec 9, 2015 09:25 AM
Uetian
R55 :: Clubman Talk (2008+)
Nov 1, 2015 05:18 AM
Shomare
Oct 28, 2015 07:16 AM
