+35 offset fit on mini countryman??
Old Nov 5, 2015 | 07:09 AM
itsfamoso305's Avatar
itsfamoso305
Hey guys
Newbie here, I want to buy some set of bbs rs wheels. The specs the company gave me that would fit my Countryman were 18x9 offset 35 but I am not sure. I do want an aggressive look and stance. I will be lowering the car with Megan racing coilovers also. Will I have a problem with those wheels?? Anybody running this wheel specs on their countryman??
Hope I get some help.
Thank you
Old Nov 15, 2015 | 05:28 AM
R60WRC's Avatar
R60WRC
Me 2
I am looking to do the same. The wheel fitment website seems to allow this.
I am looking at these.
Originally Posted by itsfamoso305
Hey guys
Thank you
Old Nov 15, 2015 | 05:51 AM
R60WRC's Avatar
R60WRC
http://www.willtheyfit.com/index.php?width=205&aspect=55&diameter=17&wheelwid th=7&offset=50&width2=205&aspect2=55&diameter2=17& wheelwidth2=8&offset2=35#content
Old Nov 16, 2015 | 08:07 AM
itsfamoso305
Those look super nice!! Are you going to run the same fitment and offset as I am??
Old Nov 16, 2015 | 08:11 AM
itsfamoso305
So do you think my fitment and offset will work??? I shouldn't have any problems?? I don't know too much about offsets or anything. According to the website it says it works???
Old Nov 16, 2015 | 04:14 PM
R60WRC's Avatar
R60WRC
Offset
I am running 17x8 35mm offset
Old Nov 17, 2015 | 06:28 AM
itsfamoso305
Ok so you think I would be good with 18x9 35 offset??
Old May 31, 2016 | 05:23 PM
ARMASPEEDUSA's Avatar
ARMASPEEDUSA
Depends how low you planning to go with your CMS. 18x9 +35 is consider aggerssive on the CMS
Old May 31, 2016 | 05:24 PM
ARMASPEEDUSA
oops, accidentally bumped a old post lol
Old Jun 3, 2016 | 08:18 AM
itsfamoso305
Thank you, still trying to decide if to go with this setup or not. Like you said it is aggressive.
Old Feb 3, 2017 | 01:42 PM
Mister Spice's Avatar
Mister Spice
i am awaiting my 255/30/20 +35MM offset Wheel and tire package to arrive.
tiresize.com and willtheyfit.com says it will fit without any noticeable speedo inaccuracy
coming from stock 225/45/18 +52MM offset and stock suspension
Old Feb 6, 2017 | 05:11 AM
HasAnMTBProblem's Avatar
HasAnMTBProblem
Wow! 255 is super wide! What width wheel are you getting? Has to be at least 8.5" I would expect some rubbing issues with that wide a wheel/tire.
Old Feb 6, 2017 | 05:45 AM
Mister Spice
8.5 wide. you see the reference tools i used to check fit?
ill see when they get in. and i will post the results.
Old Feb 8, 2017 | 11:01 AM
HasAnMTBProblem
I certainly wish you luck. I researched the hell out tire/wheel size and consulted with multiple Mini gurus/specialists. Everyone said the same thing, and my research concurred that (for my case, assuming 1.5" lowering) that 235/40R18 on 18x8 et42 wheels was widest I cold go without question. 255/30R20 on 20x8.5 et35 will be .7" wider, .6" taller, and stick out .7" farther.
Now, being that you haven't mentioned any suspension changes, maybe it'll be ok. All I know is that, if you pull it off without it rubbing and it doesn't look like a skateboard, I'm might be super jelly.
Old Feb 8, 2017 | 11:02 AM
HasAnMTBProblem
"without question" meaning without risking buying something that didn't work and then have to re-buy things.
Old Feb 8, 2017 | 08:10 PM
Mister Spice
stock suspension... from the different tools and many sources of research it looks as it will work and yes thanks for the many good wishes.. they will be here friday... .
Old Feb 8, 2017 | 08:14 PM
Mister Spice
that wheel and tire combo i chose has same overall circumference as the stock 225/45/18 +52MM offset 7" wide that came with my paceman s all4
Old Feb 12, 2017 | 08:08 AM
YVR_CMALL4_GRL's Avatar
YVR_CMALL4_GRL
Did they come?
Do you have them yet? Look? Pics? How is the 35!offset?
Old Feb 13, 2017 | 07:10 AM
Mister Spice
On the truck out for delivery now... as soon as i install for fit i will update.
Old Feb 13, 2017 | 12:58 PM
Mister Spice
255/30/20 +35 offset on 2015 R61 S All4
Here is the answer we all been awaiting. installed these today on stock suspension. clearance check to inner side wall and suspension works just as the references I used above and I just drove 4.1 Miles Not a rub or squeal. these Toyo Proxes 4 Plus tires are actually smoother and quieter than the stock P7 Cinturato All seasons.
Attached Thumbnails +35 offset fit on mini countryman??-img_20170213_152029252_hdr.jpg   +35 offset fit on mini countryman??-img_20170213_152010043_hdr.jpg   +35 offset fit on mini countryman??-img_20170213_151954798_hdr.jpg   +35 offset fit on mini countryman??-img_20170213_151922712_hdr.jpg   +35 offset fit on mini countryman??-img_20170213_151910723_hdr.jpg
Old Feb 13, 2017 | 01:16 PM
Mister Spice
i updated post about 255/30/20 with +35 offset wheels
Mister Spice
Old Feb 13, 2017 | 04:34 PM
YVR_CMALL4_GRL
Nice!
Your car looks great! I love the color and the rally lights. Surprisingly the rim size doesn't look awkward or too big. Congrats. You happy?
Old Feb 13, 2017 | 05:25 PM
Mister Spice
thank you.. yes i am very happy with the look, fit and drive ... the wife loves it. she picked out the wheels. from 3 choices CarID had available with that offset. just wanted to share this with those whom were curious if the size combo i have will fit and keep speed accurate .
Old Feb 14, 2017 | 04:34 AM
HasAnMTBProblem
Nice! A little too outboard for my taste, but glad they worked out!
