R56 Please help mini won't start
Old Nov 4, 2015 | 06:09 AM
Camilo A Londono's Avatar
Camilo A Londono
Car won't start is dead. Check beatery and beatery is fine hidden codes 931bh, 9314h, a3c3h, a3a9h.
ObdII code : P0131, P0132, P0012, P0131, P2251, P0130 please help
Old Nov 4, 2015 | 09:05 AM
nkfry's Avatar
nkfry
Welcome to the board,
A bit more information would be nice, does the car crank but not start or is it a no crank no start?
Background? When did the issue start, what were you doing and what was the weather like?
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Nov 4, 2015 | 09:11 AM
nkfry's Avatar
nkfry
P0012- Intake cam over retarded/ possible VANOS solenoid fault.
P0131- Mixture control sensor low voltage bank 1 sensor 1.
P0132- Mixture control sensor high voltage bank 1 sensor 1.
P2251- Mixture control sensor virtual earth, open circuit.
P0130- Again another mixture control fault, temperature implausibility.
Is the mixture control sensor plug full of oil? It sounds a lot like a failure we just had in the shop from oil ingress into the sensor.
Is the car in time? This can only be checked by a qualified tech with the proper timing blocks.
Phone:586-792-6464
countryman-s
Electrical
26
Jul 24, 2017 12:12 PM
Minime1963
R55 :: Clubman Talk (2008+)
11
Nov 9, 2015 07:33 AM
KurvHugger
Nov 3, 2015 02:48 PM
Z0RR0
Suspension
Nov 3, 2015 08:50 AM
Camilo A Londono
Oct 31, 2015 03:00 PM
