R56 Buzz at 2500-3000 rpm
Old Oct 31, 2015 | 01:27 PM
gpzjack's Avatar
gpzjack
My car buzzes pretty bad. Put it up on the lift today thinking i might have an exhaust leak. Still finding mods the po did. I see a Torque solutions mount on the front and it looks like its a solid mount? Could that be the source of it?
Car is pretty quiet at lower and higher rpms. Also found a Alta hot side tube and the car has a aem intake.
Old Oct 31, 2015 | 04:09 PM
NeonLed's Avatar
NeonLed
https://www.northamericanmotoring.co...om-engine.html
Old Oct 31, 2015 | 04:15 PM
gpzjack's Avatar
gpzjack
My problem seems different than described there. More like a exhaust leak. Or a muffler droning. I've read others having a similar issue with alot of intake mods and no tune. Car pulls super hard and is quiet at higher or lower speeds.
Old Oct 31, 2015 | 06:46 PM
GEMSTER's Avatar
GEMSTER
Acceleration or deceleration?
Old Oct 31, 2015 | 06:49 PM
gpzjack's Avatar
gpzjack
At 65 mph it sounds like a car with a aftermarket exhaust droning. I see some soot on the muffler but every else looks clean.
Old Nov 2, 2015 | 07:42 AM
gpzjack's Avatar
gpzjack
I'm thinking it could be a slight exhaust leak at he downpipe gasket? I've read where others have failed?
Old Nov 2, 2015 | 08:04 AM
NeonLed's Avatar
NeonLed
Like the clamp that connects the DP to the flex joint on the exhaust is loose?
Old Nov 2, 2015 | 08:14 AM
gpzjack's Avatar
gpzjack
I'm thinking up high near the motor. I had it on the lift and everything underneath looks ok. Only soot i saw was at the back of the muffler. Weep hole?
Old Nov 6, 2015 | 05:05 AM
NeonLed's Avatar
NeonLed
Your DP could be loose on the turbo so it leaks a little.
Old Nov 6, 2015 | 01:26 PM
gpzjack's Avatar
gpzjack
thats what im thinking. its the only thing i haven't checked yet. gotta find some time this week.
Old Nov 8, 2015 | 09:41 AM
gpzjack's Avatar
gpzjack
pulled the heat cover this morning. everything looks good. The only place on the entire exhaust that i see soot is on the muffler right where the one tailpipe meets the muffler at the back of the car. Could i have a bad muffler?
1chaos52
May 24, 2020 03:07 PM
Vader-S-All4
Oct 13, 2015 06:26 AM
Thomas S
Oct 5, 2015 04:57 PM
tacticalbacon02
Oct 5, 2015 10:54 AM
MGBill1186
Oct 2, 2015 06:54 AM
