R50/53 Help reassembling my 2005 S
Old Oct 11, 2015 | 12:10 PM
Alaska_Matt's Avatar
Alaska_Matt
So let me first off start by saying that I'm kinda an idiot for doing what I did, and to thank everyone for their help in advance.
Short of the long, picked this car up with a blown motor for cheap. Took the motor our and bagged all the parts (so I thought) and ordered a new engine 2 months later when I had the time to install it. Now I can't remember where half this stuff goes. I'll post pictures of what I'm looking at and maybe people here can find it in their hearts to assist me Thanks again.
Old Oct 11, 2015 | 12:12 PM
Alaska_Matt
Where does this hard plastic tube connect to on the other side and how is it routed? <br/>
Old Oct 11, 2015 | 12:32 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Did you check the realoem website?
Old Oct 11, 2015 | 01:49 PM
Finhead's Avatar
Finhead
That plastic line goes from your breather valve in your pic on the left side. Goes under the intercooler infront of the fuel rail over to your throttle body.
You can see it here infront of the fuel rail, this is not my image but one from Pelican, that is why the green arrow is there nothing to do with the plastic line your looking at.
Old Oct 11, 2015 | 04:32 PM
Alaska_Matt
Which leads me to my next question. The hard grey plastic line that attaches to the valve cover, where does that one hook up
Old Oct 11, 2015 | 05:10 PM
Finhead's Avatar
Finhead
HMMMM Your welcome?
And to the top of your Supercharger. Here are a few links, fill your boots.
http://www.pelicanparts.com/techarti...tech_index.htm
http://www.partsbase.org/bmw/mini-r5...e-cooper-s-us/
Old Oct 12, 2015 | 05:00 AM
Spencer Roper's Avatar
Spencer Roper
Thanks Fin
Old Oct 21, 2015 | 12:59 PM
Alaska_Matt
Starter wiring question now Finn I've got everything else lined up. I had to pull the intake system and switch the main wiring harness around because I had it backwards. Now I have 2 large black wires that look like they could almost both go to the starter motor. I'm having trouble posting clear photos. Do you know how many power wires run to the starter motor and if it's only one, what else behind the block requires that much power. Thanks!
Old Oct 21, 2015 | 06:22 PM
David.R53's Avatar
David.R53
Two big wires to the starter. One heads back to the battery, one heads to the alternator. Both attach to the same post on the starter.
yukinoinu
11
Sep 25, 2015 09:48 AM
Marioalex24
Sep 21, 2015 11:08 AM
keen
Sep 17, 2015 12:06 PM
Porthos
Sep 16, 2015 04:55 PM
ZeroGravity
Sep 15, 2015 06:43 PM
