PCV Oil Leak
Old Sep 27, 2015 | 01:39 PM
donniedarko's Avatar
donniedarko
PCV Oil Leak
So after finally getting in there Ive discovered there is a precipitous amount of oil leaking there. I took a picture thought it might be the Chain Cam Tensioner bolt. It is not.
I was going to install a http://www.saikoumichi.com double OCC. Id appreciate an opinion here if you might have one.
Car is gobbling oil.
Picture attached. TIA
Old Sep 29, 2015 | 01:16 PM
Looks normal it the tube is not seated all the way in. Its not the PCV hose ( that's the smaller one ). Its the intake hose / pipe before the intake manifold. You can get a little bit of residue there. Pull the tube out and clean the connection , then reinsert and tighten up. You should not see any oil seeping till way down the road, all i can think of is a turbo oil leak inside and getting a bunch of oil in the intercooler and pipe system past the turbo. Have you checked the intercooler and turbo ?
woodstudio
Mar 15, 2020 08:28 AM
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Laura Redd Casler
Aug 15, 2015 09:32 PM
azntaiji
Aug 13, 2015 03:24 PM
