Drivetrain DIY Downpipe Install
Old Sep 26, 2015 | 05:06 PM
UncDeo's Avatar
UncDeo
Looking to do this tomorrow....anybody have a how to written up? Thanks!
Old Sep 27, 2015 | 06:08 PM
UncDeo's Avatar
UncDeo
Top double ended bolt is not coming out.....neither is the second o2 censor....soaking with pb blaster.....any other tips?
Old Sep 28, 2015 | 08:38 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Were you able to get them out? For the double ended bolt, heat for the bolt will help loosen it so that you can walk the nut out. This guy in this NAM thread here had a similar issue with it being stuck while removing his downpipe. Post #4 is his solution. Hope this helps if you're still having issues.
888.280.7799 | 6am - 5pm PST
Old Sep 28, 2015 | 07:14 PM
UncDeo's Avatar
UncDeo
I didn't get back to it tonight...but I think i just need a breaker bar for the o2 sensor. What happened on the double ended bolt was....the nut came off...but the bolt didn't move....the other two came out just fine. Torch it + vise grips?
Old Sep 29, 2015 | 08:30 AM
PelicanParts.com
Vendor
Yes, heat helps. Try applying it to the bolt alone and not the surrounding materials. Then maybe take a hammer or vise grips to help you push/pull it out. For the O2 sensor, the thread that I linked the guy said, "I ended up running the car to heat up the down pipe and then using a 22mm open ended wrench instead of the socket. The wrench had a much better grip on the sensor." Maybe try that out and see if it helps.
Old Sep 30, 2015 | 07:28 PM
countryboyshane's Avatar
countryboyshane
Should be relatively self explanatory for a handy guy. So the question is, what is the hang up you're having doing the job?
Old Oct 1, 2015 | 07:08 AM
rckrzy1's Avatar
rckrzy1
there is like 3 bolts/nuts to hold the heat shield that aint never going back on. You'll figure that out. It has plenty without them.
Also found lossening the bottom bracket mounts made it work so much easier, this was the only way I found to get DP onto turbo.
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
