Cooper (non S) Modifications specific to the MINI Cooper (R56).
choosing an ECU tuning house
Old Sep 24, 2015 | 09:55 PM
genik's Avatar
genik
When deciding to tuning the ECU of the mini, what should one keep in mind in order to select the best ECU tuning house? For example, for me, its a plus to be able to toggle between the stock and the tuning maps that have been programmed in the mini. What else should i be looking for?
Old Sep 25, 2015 | 04:41 AM
ZippyNH's Avatar
ZippyNH
You cannot "toggle" in a MINI....that's more of movie thing with a Honda...
That's something you would need a standalone ecu to do.
To switch you would need to plug a "tool" into the ecu, car off, and upload the software, each time, the ecu records a rewrite of software....
Old Sep 25, 2015 | 05:24 AM
thebombardier's Avatar
thebombardier
Manic offers something like what you want. You have to buy an SPS switcher dongle separate from the tune to switch between maps. You get the car tuned then with the car off but they key fob plugged in you plug the SPS into your OBDII port with the **** turned to the setting which corresponds with the desired ECU map. Wait a few seconds and remove the SPS and turn the car on.
When I got my Manic tune I just bought the SPS switcher at the shop. I can literally do it while stopped at a traffic light. Shut down, turn the **** to setting 2, plug in, remove, start up. Bam, I'm back to stock. Next light, same process with the **** on 5 and I'm making 200+ hp at the wheels again.
As far as having a button or a switch though mounted somewhere in the car or being able to switch it around with controls in the car, there is no such thing out right now.
EDIT: Just realized this is the non-S section. Not sure if Manic does tunes for the regular Cooper. But the point remains, you need a separate switcher to choose maps with these cars.
Old Sep 25, 2015 | 02:02 PM
genik's Avatar
genik
Good Lord, i just realised that too now! Im not asking this for a nonS. Can a moderator place this thread in the right place?
Old Sep 25, 2015 | 02:25 PM
cerenkov's Avatar
cerenkov
You don't need to shut the car off to switch tunes with Manic. You can do it while driving. You could use a OBD extension cable and mount the SPS switch in the dash somewhere.
Not sure why you really want to switch maps all that often. I use the same map 99% of the time.
Old Sep 25, 2015 | 02:46 PM
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by cerenkov
You don't need to shut the car off to switch tunes with Manic. You can do it while driving. You could use a OBD extension cable and mount the SPS switch in the dash somewhere. Not sure why you really want to switch maps all that often. I use the same map 99% of the time.
Exactly, I don't change maps often, but when I do, I can do it while I'm driving at 80mph, in just a little coordination
mQubed Motorsport, Manic Tuning Dealer
Jan 4, 2019 12:51 PM
AdrenaliNate
Nov 4, 2015 07:26 PM
Aug 21, 2015 11:25 AM
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
