2009 JCW clutch job in progress
Old Sep 24, 2015 | 02:03 PM
sikamini's Avatar
sikamini
Hi y'all. I have a 2009 JCW and a while ago the clutch gave out. Last weekend I finally got the clutch out and apart. The clutch disc is at it's minimum of around 1mm slightly under. The throwout bearing lever fork actually failed at the throwout bearing. It was just sort of hanging around the shaft. Since I have it all out I'm replacing the fork, bearing, clutch disc and clutch for sure. No signs of leaks. The dual mass flywheel is my big question. It's not scored and as far as the bearing area looks okay. In the ol' days 30 years ago I would have taken a piece of sand paper to it and then used it. Frankly I'm not knowledgeable about the dual mass flywheels and I'm trying to figure out if it's still okay. It's pretty stiff and less than a 1 mm rock. Tips and experience appreciated. I'll be ordering parts soon. I suppose if I go and order from Momentum I could ask a mechanic to verify. Y'alls thoughts, thanks!
Old Sep 25, 2015 | 01:38 PM
sikamini's Avatar
sikamini
Doesn't seem like there are not many do it yourselfers left here. I've decided to that the flywheel is good. If it's not I'll let y'all know when I pull it out again!
Old Feb 16, 2017 | 04:12 PM
troyegly's Avatar
troyegly
Sorry no body replied! I hope it all worked out
Old Jun 21, 2017 | 12:29 PM
sikamini's Avatar
sikamini
Worked out just fine. Few other jobs since then and a few more coming up. The clutch job is not difficult just takes time and patience.
Sexual Chocolate
Mar 31, 2019 08:02 PM
marendt428
Nov 14, 2015 10:03 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
2manyhobbies
Aug 9, 2015 06:02 PM
marendt428
Aug 8, 2015 04:44 AM
