R50/53 Tell me about LSD, man.
Old Sep 19, 2015 | 02:05 PM
Greezyman's Avatar
Greezyman
I wanna take a trip, to look at some used MINIs, and I'd like to know if there's a way to tell if they have a limited slip diff. I could just drop the clutch and see if they leave one or two stripes, but that wouldn't be polite to do in a car that isn't mine. Is there anything external I can see, or can I decode the VIN, or... ?
Also, were all R50s and R53s available with lsd? Were there different kinds of lsds available? Thanks.
Old Sep 19, 2015 | 03:22 PM
jamez's Avatar
jamez
R53's were available with them (but were a rarely selected option), and they came with the factory JCW package in Fall 05 builds
You can find out if the LSD came from the factory by looking up the VIN in the BMW VIN Decoder (google it). You will need the last 7 digits of the VIN.
It will be listed in German, something like Superdiferezal (I didn't spell it right)
You can also get a much better LSD in the aftermarket for around $1K and put it in with the next clutch job.
While I lucked out and got it on both of my cars, it would not stop me from buying an R53 if it didn't have one (because I would install an aftermarket one). In my opinion it is a necessary upgrade if you are looking for performance.
Old Sep 19, 2015 | 03:53 PM
Anakist's Avatar
Anakist
Apparently if the gearbox number ends in TKBL (iirc) it comes with an LSD.
James
Old Sep 19, 2015 | 04:45 PM
rkw's Avatar
rkw
It was never available for the R50. For the R53, it was an option available only in 2005 and 2006. There was only one type of factory LSD. It is a rare option (very few customers ordered it).
Old Sep 19, 2015 | 08:40 PM
MiniSMan's Avatar
MiniSMan
The Used 2006 R53 i Bought this past Feb has the LSD Option ..i decoded my Vin# on the BMW website ..
Old Sep 21, 2015 | 05:31 AM
Saltysalt's Avatar
Saltysalt
an easy way to tell is to jack up the car to where both front tires are off the ground, spin one wheel, if only one spins in neutral you have a limited slip, if the other wheel spins the same direction, theres a semi locker diff or locked diff, if the other wheel rotates in the opposite direction its an open diff
you can do the BMW Vin check, but that will only tell you if it came with one standard. and its correct, only 05 and 06 had those available options
bahman
Aug 6, 2016 07:19 AM
vulkandino
Oct 31, 2015 08:29 PM
bahman
Sep 30, 2015 01:59 PM
Sep 28, 2015 09:13 AM
Anakist
Sep 23, 2015 08:05 PM
