205/50-16 and the lowered Mini
Old Aug 10, 2004 | 04:24 PM
DragonSlayer's Avatar
DragonSlayer
Ok;
I did some searching and didn't quite get the answer I was looking; So; I will ask it.
Will 206/50-16 fit on a lowered MINI with Eibach springs?
Old Aug 10, 2004 | 06:42 PM
kenchan's Avatar
kenchan
As long as the offset of the wheel is 42-48mm and width of
wheel is 7.5" or less, should fit without any problems.
Old Aug 10, 2004 | 07:13 PM
scobib's Avatar
scobib
I'm running 205/50R16 Yoko ES100's on my car, on Rota Slipstreams, which are 16x7 and 42 offset. I've got H&R springs, which dropped my car 40mm all around, and I've got no rubbing!
Old Aug 10, 2004 | 08:02 PM
DragonSlayer
What's the offset on the stock 5 spokes?
Old Aug 10, 2004 | 08:16 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by DragonSlayer
Ok;
If you have 16" R83 stock 5 spoke rims then your offset is +50mm and you will be OK to run 205/50-16 tires on your MINI with Eibach springs.
Old Aug 10, 2004 | 08:33 PM
DragonSlayer
Perhaps I misunderstand the + and - of offsets. I had assumedthat a + would be how much more the outside edge of the rim was from center than the outside edge was from center. Sounds as though its the other way?
Old Aug 10, 2004 | 08:53 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Wheel offset info here:
http://www.tirerack.com/wheels/tech/offset.htm
Sound like they should fit.
Did you get a deal on some tires?
Old Aug 10, 2004 | 09:43 PM
DragonSlayer
No Both rear run flats are damaged and I'm looking to replace them. Was checking out the options. I think I'm going to buy a full set of yoko's
Old Aug 10, 2004 | 09:45 PM
dave's Avatar
dave
pug poo picker-upper
I had 205/50 R16 AVS ES100's on my MINI with H&R's on the stock 16's. There was no rubbing. The H&R's lower the car more than the Eibach's as I recall.
Old Aug 10, 2004 | 10:21 PM
kenchan's Avatar
kenchan
Did you not even look at the PM reply I sent you earlier this evening?
jeremy_reyes94
Sep 6, 2019 07:53 AM
flredmini
Apr 5, 2016 06:21 AM
nomar116
Aug 12, 2015 05:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
