R56 Adding front plate
Old Sep 13, 2015 | 06:38 PM
FLKeith's Avatar
FLKeith
Adding front plate
I have moved from FL to NH so need to add a front license plate to a 2007 S. Before I drill holes, can someone tell me what is behind the two points in the front bumper that seem ready for the plate. Are there threaded holes behind the plastic cover or are they just the suggested place to put self tapping screws into the bumper? Any suggestions on the best way to add a plate? Thanks
Old Sep 13, 2015 | 07:10 PM
GeneralSpecific's Avatar
GeneralSpecific
I'm guessing you're talking about the tow hook mount, several vendors make a plate bracket for it. I wish I knew about them before I drilled my holes...
Here's the first one I found searching, others will no doubt chime in:
http://www.cravenspeed.com/mini-plat...e-plate-mount/
Edit:
ohhh I just realized what you meant. Yes, they're just dimples for locating the screws. There aren't any threaded holes behind them - just plastic.
Old Sep 13, 2015 | 08:08 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes the dimples just use self tapping screws into the plastic.
But if you don't want to cut holes in the bumper you can use the craven plate mount
http://www.waymotorworks.com/cravens...te-holder.html
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
