R56 Excessive boost..?
Old Sep 13, 2015 | 10:58 AM
gzaos's Avatar
gzaos
Excessive boost..?
2007 MCS, stock mostly everthing, mechanical boost gauge is installed and lately Ive been seeing as high as 15-16 psi with fluttering boost. Cool and all if I had planned it, not the case. From low RPM at WOT it shakes my car/ halts acceleration and makes a light grinding noise, wondering if the noise is from turbine? Also tons of blueish black smoke. Hard to tell if its unburned fuel or oil color. But at high RPM when I put my foot in it, accelerates normal. Been researching it a bit, and wondering if it could be stock recirculating valve malfunctioning? Have been very nice to the mini since the issue has started. Checked the vanes, did not notice any free movement with them or any oil, hoping it is still early enough to salvage the turbo. Oh 73k miles on the car and little in repair costs, so overall a happy R56 owner here. Thanks for any input
Old Sep 13, 2015 | 12:06 PM
rckrzy1's Avatar
rckrzy1
CARBON BUILD UP, it's guaranteed in the 2007 , and more carbon means less air space, means more compression. You most likely need valves cleaned.
Old Sep 13, 2015 | 12:57 PM
gzaos's Avatar
gzaos
I had the local BMW shop use the chemical cleaner on them a few months back, does it not sufficiently clean them like walnut blasting will? Idle picked back up after it happened.. I work at a sandblasting/ powder coating shop, so can i pick up walnut shells and use our blast cabinet myself? Or is there a reason to take it to a shop to reassemble after. Thanks
Old Sep 13, 2015 | 01:14 PM
rckrzy1's Avatar
rckrzy1
Not a chance with anything but walnut blasting.
QUOTE=gzaos;4123609]I had the local BMW shop use the chemical cleaner on them a few months back, does it not sufficiently clean them like walnut blasting will? Idle picked back up after it happened.. I work at a sandblasting/ powder coating shop, so can i pick up walnut shells and use our blast cabinet myself? Or is there a reason to take it to a shop to reassemble after. Thanks[/QUOTE]
Old Sep 14, 2015 | 03:51 AM
Systemlord's Avatar
Systemlord
A grinding noise with blue, black smoke sounds like un-burnt fuel and oil. As far as the grinding noise it could be anything, you need to remove the intake charge pipe and feel the turbo shaft for excessive play with only your fingers. Far more than a carbon build up issue. There's only one way to remove oil coked carbon that has been cooking itself to your intake valves for 73,000 miles, my carbon deposits after 63,000 miles was as hard as sandstone!
Old Sep 14, 2015 | 04:21 AM
cerenkov's Avatar
cerenkov
Excessive boost..?
What do you mean by low RPM and what gear?
Lugging the engine (WOT at low RPM in the mid to higher gears. For example, 3rd or 4th gear at 2000 RPM) puts tremendous stress on the engine and is and can cause numerous problems.
obscurity2
Oct 26, 2015 11:37 PM
schr5530
Oct 5, 2015 08:28 AM
M7Speed
Oct 1, 2015 07:05 AM
CooperT
R60/R61 Stock Problems/Issues
Sep 22, 2015 12:54 PM
Sep 21, 2015 09:04 AM
