limp mode (Safe Mode) how to fix it
Old Sep 12, 2015 | 05:41 AM
ahmedalsurmi's Avatar
ahmedalsurmi
Hello
i have mini r56 and im in limp mode (Safe Mode) how to exit from it or reset it
i have this code sortted only
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
please help me to fix this and what should i do
thanks
Old Sep 12, 2015 | 06:19 AM
Drivehard's Avatar
Drivehard
Well with a 106k on the clock I'd go with you need a new oxygen sensor.
If you read the codes then you have the ability to clear them. Did u try clearing and see if it comes back ?
Sent from my iPad using NAMotoring
Old Sep 12, 2015 | 06:23 AM
ahmedalsurmi
yes i have cleared the code
and they come back again
but does it make car go into limp mode
Old Sep 13, 2015 | 02:05 AM
Systemlord's Avatar
Systemlord
A new O2 sensor will fix this, clearing the code should be done after fixing this, clearing the code will not fix the faulty O2 sensor. ECU will not necessarily go into Limp Mode every time a code is thrown.
If you had Googled "P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)" you would have found your problem here which tells you what's wrong with your car.
Old Sep 13, 2015 | 04:40 AM
ahmedalsurmi
hi thanks for your replay
what should i replace which is located on top or bottom
thanks
Old Sep 13, 2015 | 05:00 AM
ahmedalsurmi
sorry
i mean after cat or before cat ?
Old Sep 13, 2015 | 05:10 AM
Porthos's Avatar
Porthos
Its after the cat about half way down the car.
Old Sep 13, 2015 | 05:12 AM
ahmedalsurmi
Old Sep 14, 2015 | 02:29 AM
ahmedalsurmi
Originally Posted by ahmedalsurmi
sorry
i have replaced o2 sensor and check engine go away
and im still in limp Mode (Safe Mode)
please help what should i do the car runing very slow
everything is new spark plug and coils and all filters Fuel Air And Oil Filters
Old Sep 14, 2015 | 02:55 AM
Systemlord's Avatar
Systemlord
Clear the code.
Old Sep 14, 2015 | 04:27 AM
ahmedalsurmi
Clear the code.
i have cleared the code and still the same
Old Sep 14, 2015 | 05:12 PM
Porthos's Avatar
Porthos
Replace the other o2 sensor then. See what happens. Is it the same code that keeps popping up?
Old Sep 14, 2015 | 11:48 PM
ahmedalsurmi
nothing is shown no faults at all
Old Sep 15, 2015 | 12:12 AM
Porthos's Avatar
Porthos
So you are getting a CEL with no codes and it won't reset? Are you tuned?
Old Sep 15, 2015 | 12:42 AM
Systemlord's Avatar
Systemlord
Disconnect the battery for an hour then reconnect, that should reset the ECU. Which O2 sensor did you replace, Bank 1 Sensor 1 or Bank 1 Sensor 2?
https://www.google.com/search?q=Bank...thtsjoku9iM%3A
Old Sep 15, 2015 | 02:20 AM
ahmedalsurmi
replaced bank 2
and i have disconnect battery and still the same
Old Sep 15, 2015 | 06:08 AM
ahmedalsurmi
no its factory without any tune
Old Sep 15, 2015 | 11:13 AM
Systemlord's Avatar
Systemlord
It must be the wiring, time to have a continuity test between where you connect the O2 sensor and the ECU.
Old Oct 31, 2019 | 02:51 PM
Charles Caruth's Avatar
Charles Caruth
just bumping this thread. having the same problem curious if you figured it out.
Old Sep 25, 2023 | 04:35 AM
fix's Avatar
fix
Hi guys did you fix the problem?
Old Sep 25, 2023 | 04:49 AM
Charles Caruth
i never did figure it out, couldn’t afford to keep throwing parts at the car, ended up selling it but still stuck on it afterwards thinking what it could’ve been I landed on most likely my issue being the diverter valve. Hope that helps!
thadscottmoore
Jun 4, 2021 07:19 AM
Sc00terbum
Sep 11, 2015 07:17 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
