R52 Newbie looking for coolant answer
Old Sep 6, 2015 | 04:08 AM
jef1f's Avatar
jef1f
Can someone please tell me the name of the recommended coolant to use in a 2005 cooper s
Old Sep 6, 2015 | 10:24 AM
MichiganMike's Avatar
MichiganMike
There are extensive threads discussing recommended and compatible coolants.
https://www.northamericanmotoring.co...nt-to-use.html
The short answer is MINI offers a coolant through its dealers and others which is recommended. Zerex G-05 is often recommended as an alternative.
https://www.northamericanmotoring.co...g-coolant.html
Good luck.
Old Sep 8, 2015 | 07:51 AM
quikmni's Avatar
quikmni
I just stick with the Mini coolant. I do not live near a dealership so I order online.
Old Sep 8, 2015 | 08:05 AM
Helix13mini's Avatar
Helix13mini
^this^
Old Sep 8, 2015 | 08:09 AM
ZippyNH's Avatar
ZippyNH
Strongly suggest going to a BMW/MINI dealer, and buying a jug...
It was actually cheaper than the ZEREX G05, which ALMOST meets the spec, but is still different...
Old Sep 8, 2015 | 08:57 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1
MINI Coolant here if needed.
888.280.7799 | 6am - 5pm PST
Old Sep 17, 2015 | 01:05 PM
Norton70's Avatar
Norton70
how much coolant does a 2006 S hold?
Old Sep 17, 2015 | 01:09 PM
PelicanParts.com
Vendor
The MINI Cooper S holds 6 liters or roughly 1.5 gallons of coolant. More info here.
Old Sep 18, 2015 | 07:59 AM
Make sure the coolant is mixed 50/ 50 with distilled water as the Blue coolant is in concentrate form. Most MINI system are total 8.5 liters. Better to hard more then not enough already mixed.
https://www.ecstuning.com/Search/SiteSearch/82140031133/ES196253/
Old Sep 18, 2015 | 02:49 PM
zr0z's Avatar
zr0z
Where are you seeing most mini systems having 8.5 liters? I just picked up coolant (unfortunately not from you guys) and the dealer and my own research confirmed one bottle is fine (as it needs to be mixed 50/50) and the R53 / R52s take 6 liters total.
vulkandino
Oct 31, 2015 08:29 PM
simo711
Oct 8, 2015 07:07 PM
micromini234
Sep 30, 2015 07:36 PM
point665
Sep 29, 2015 12:41 PM
silence2-38554
Sep 28, 2015 12:19 PM
