R56 heating system questions
Old Jul 30, 2015 | 11:14 AM
peatun's Avatar
peatun
Anyone know how the heater core system works? Is there a shut off valve for the coolant when you have the heat off? I ask because the center console on mine can almost burn my leg. It's 90+ outside and it's still passing hot water through the core which makes a load of heat inside that the AC is having to compensate for.
I took the side cover off and put some insulation wrapped in tin foil between it and it's helped a little bit but this thing is too hot to even touch sometimes.
TIA
-P
Old Jul 30, 2015 | 11:59 AM
Slave to Felines's Avatar
Slave to Felines
This behavior is not uncommon. In fact, there is a TSB for it--they basically put more insulation on the line, as you have done. We have heard reports that a failing thermostat can add to the heat coming from there, but I'm not sure how that would work.
Old Jul 30, 2015 | 12:13 PM
eliseo1981's Avatar
eliseo1981
I am in Texas and noticed the same thing on mine, we have 100 degree weather here and its hot, not burning leg hot but definitely noticeable. I wish it had a thermometer gauge for the engine.
Old Jul 31, 2015 | 11:17 AM
peatun's Avatar
peatun
Is the coolant always going through the heater core or does it get shut off when the temp is set low on the heat? I checked the temp on mine after I took it apart so it wasn't running for a few mins and it was still 150 degrees.
Elio I use the scan gauge to permanently see a temp gauge, I wouldn't drive a car without one, especially one with an aluminum head.
Old Aug 3, 2015 | 02:19 AM
Systemlord's Avatar
Systemlord
The hot coolant always travels through the heater core, I talked with my local Mini dealer and the SA said that there was no service bulletin even after I showed him a copy of the service bulletin, it's like talking to a brick-wall! I called Mini USA (not to bright either) about hot air burning my foot in my sandals while traveling to the beach.
I emailed MINI USA service Rep the service bulletin regarding the heater core issue and it took 2 months for her to get back to me. Two months later the service Rep emailed me the same service bulletin I email her and she said there was a service bulletin for the heater core. OMG!
Sometimes I feel like I'm talking to someone less than human, I painted a clear picture for both of them and they completely missed it. These people don't belong in their current professions in my opinion!
Old Aug 3, 2015 | 04:37 AM
peatun's Avatar
peatun
Systemlord what did the TSB fix do?
Old Aug 3, 2015 | 10:47 AM
Systemlord's Avatar
Systemlord
They installed insulation around the 2 heater core pipes. No more hot foot.
Old Aug 3, 2015 | 10:49 AM
peatun's Avatar
peatun
Thanks! Not worth the time in my case, I've already done that.
Old Aug 3, 2015 | 01:02 PM
Here is the old TSB : Looks like part # 64113453594
https://www.northamericanmotoring.co...tting-hot.html
Old May 19, 2016 | 02:46 PM
Dougtunh's Avatar
Dougtunh
Heater core very very hot
I have a 2007 Mini . The heater core is hot that it will burn you if you touch it.. We have had the car for several years and never noticed this before. I replaced the thermostat 2 years ago due to a leaking cracked housing. Is my car overheating? It runs fine and gives no indications of overheating . What is the operating temp for this car? How do check it?
Doug
Old Jun 3, 2019 | 06:57 AM
Lex2008's Avatar
Lex2008
Anyone have a pic of the insulation, part 64113453594? Is it worth $50 or am I better off just using some pipe insulation from Home Depot?
jeffbeckhudd
Aug 29, 2015 09:11 PM
minicoclub
Aug 25, 2015 09:07 AM
Powershift
Aug 16, 2015 05:14 PM
Aug 12, 2015 01:24 PM
