R58 Stripe protection
Old Jul 24, 2015 | 02:59 PM
dedalus5550's Avatar
dedalus5550
Stripe protection
I guess this is a common issue where the white bonnet stripes become yellowish/brownish. Closest dealership said I had to take it to the dealer where I bought it. Pain, but at least they replaced them. Anyway, the first dealership told me about some product that is sold in boating stores that will prolong the stripes. They said it's Ducky or Hot Sauce. Both companies sell a lot of products, from cleaner to protectant, but which one. They first seemed so sure, now the guys at the dealer are not too sure about which one.
Any advice?
Thanks,
Mike Todd
Old Jul 24, 2015 | 06:00 PM
dube53's Avatar
dube53
Any advice?
Thanks,
Mike Todd
You should use a top end synthetic wax as Meguiars Ultimate and wax your car twice a year.
It is the reason I never wanted stripes. They fade and need to be replaced often depending of the climate you live.
Old Jul 31, 2015 | 10:26 AM
Just use a wax or detailer with good UV protectant and you should be fine.
I have white and use the speed wipe. Smells like cherries.
http://www.ecstuning.com/Search/SiteSearch/ES2770314/
" Chemical Guys Speed wipe cleans, shines, and protects using advanced UV solar blocking technology. "
Old Aug 15, 2015 | 09:44 AM
Grumpy_i_m's Avatar
Grumpy_i_m
After a 150 mile drive to Oklahoma City, I am at the MINI Dealer this morning. The coupe was due for service.
I told the SA about my silver stripes showing brown lines and will not just go away with cleaning or polishing.
He looked at the stripes and placed them on order. They will call when the new stripe kit arrives. no questions no hassle.
I really did not have any other issues to bring up.
The S Coupe has been trouble free for the 12000 miles.
Still a blast to drive.
Jackie Cooper MINI has so far been very good to deal with.
I will follow up after the stripes are replaced.
Keep on Motoring
Old Aug 15, 2015 | 10:00 AM
NigelynMINI's Avatar
NigelynMINI
This looks like good stuff! do you have a direct link to purchase?
Old Aug 15, 2015 | 03:05 PM
Fly'n Brick's Avatar
Fly'n Brick
UH, Nigley, click the link ECS included in their post. ESC is a VENDOR.
Last edited by Fly'n Brick; Sep 27, 2015 at 09:51 AM. Reason: couldn't spell ECS - came out ESC by mistake
Old Aug 15, 2015 | 05:20 PM
danjreed's Avatar
danjreed
As a side note, much stripe damage occurs from the un-insulated hood.
Adding a heat barrier, even reflective foil tape goes a long way in keeping the hood cooler, and the stripes happier.
Old Aug 15, 2015 | 06:14 PM
Grumpy_i_m's Avatar
Grumpy_i_m
Dan
In the case of my S coupe, the stripe discoloration is front and rear stripes.
My MINI has full under bonnet insulation with an additional aluminum insulation pad above the turbo.
The dark green stripes on the roof are perfect.
I have seen on other Mini models, deformed scoops, and damaged stripes that are obviously caused by heat from the turbo, the damage did not look like the brownish mottling I see on my Coupe.
The upward facing surfaces front and rear are involved.
I do believe the cause is UV related, however, the dealer has applied UV protectant when took delivery and again at my first service.
At this point I am open to any solutions however the un-insulated bonnet is not the cause in this case.
Keep on Motoring
Old Aug 15, 2015 | 06:36 PM
danjreed's Avatar
danjreed
Ok, roger that.
Old Aug 16, 2015 | 07:55 AM
PHL_FLYERS's Avatar
PHL_FLYERS
I have a 2014 Mini Cooper Coupe S Spice Orange and Black and my orange stripes began bleaching white about 6 months ago. The dealer replaced all but my JCW wing stripes. Spice orange stripes can not be found or at least I haven't been able to locate them. I wash my car every week faithfully and use Detailers. You name it I've tried it. I also keep my car highly waxed. From front bumper to rear bumper including side trims. Still stripes bleach. My car i'd say 90% of the time is under a cover away from the sun. it's that 10% a work that it doesn't have a cover that causes the bleach. I've purchased Spice Orange spray paint to go over the stripes on the JCW wing. I'm going to wait about a week to see if anyone has any suggestions on getting the spice orange stripes for my JCW wing before I go about using the spray paint.
Old Aug 17, 2015 | 05:58 AM
Seems like allot of the coupe' / Roadster stripes first couple batches of stripes all had the water spot or fading issues , had mine replaced and have been using the CG stuff on the new ones , good stuff and no issues.
Also I had the stripes fade first on the roof, so no heat from the hood there.
Old Aug 17, 2015 | 02:44 PM
TheBigNewt's Avatar
TheBigNewt
My Coupe had red hood/boot stripes on the gray parts and black stripes on the red top. Delivered to dealer 7/13. I bought it 4/14 stripes perfect. Used drivethrough carwash once. Roof stripes faded to gray, red hood stripes still perfect. Had roof stripes removed. Red hood/boot stripes still perfect a year later. Go figure.
Old Aug 18, 2015 | 05:36 AM
What I have seen for the 2012 and 2013 on lot , allot of the roof stripes were faded ? So it seems all over the place. One person told me they had a bad batch in 2012 or roof stripes from germany for the coupe.
Old Aug 18, 2015 | 10:14 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Try contacting MightyStripes.com here. They might be able to get you what you're looking for.
888.280.7799 | 6am - 5pm PST
Old Sep 27, 2015 | 06:30 AM
Grumpy_i_m's Avatar
Grumpy_i_m
Originally Posted by Grumpy_i_m
After a 150 mile drive to Oklahoma City, I am at the MINI Dealer this morning. The coupe was due for service. I told the SA about my silver stripes showing brown lines and will not just go away with cleaning or polishing. He looked at the stripes and placed them on order. They will call when the new stripe kit arrives. no questions no hassle. I really did not have any other issues to bring up. The S Coupe has been trouble free for the 12000 miles. Still a blast to drive. Jackie Cooper MINI has so far been very good to deal with. I will follow up after the stripes are replaced. Keep on Motoring
Due to some health issues that delayed being able to get my Coupe to the dealer, I drove the 150 miles and just dropped it off at Jackie Cooper MINI in Oklahoma City . I left the Mini coupe with them and they are installing the new Stripes this week. I will follow up with the results after I pick it up later this week. Other than the stripe issue the S Coupe has been trouble free. I have however replaced the Conti Run Flats with Michelin pilot super sports, the Michelin SS tires have improved the responsiveness and reduced road noise. I recommend them highly. Keep on Motoring!
Old Sep 27, 2015 | 11:31 AM
qwispichkn's Avatar
qwispichkn
Don't wax over stripes. You want to use a UV protectant. I use 303 Aerospace protectant. Once a month. I just use it when I wash the car.
Old Sep 27, 2015 | 04:57 PM
PHL_FLYERS's Avatar
PHL_FLYERS
Thanks for the contact info I actually contacted the Mini dealer who had recently replaced the stripes on my Coupe all except for the JCW wing and they are replacing the stripes on the wing as well. They said that they had not looked at the wing when the stripes were replaced and that because the stripes come as a kit they didn't order extra for the JCW wing since the JCW wing was an add on after purchasing the Mini. Good thing was that I purchased the wing from the dealer and they installed it along with the stripes so they were receptive to replacing the stripes. Thanks again for the contact info. Have looked at their stuff for future projects.
Old Sep 28, 2015 | 08:08 AM
PelicanParts.com
Vendor
You're very welcome and I am glad the dealer is taking care of it for you.
Old Sep 29, 2015 | 05:39 AM
The CG stuff has worked great in the past for the 2005. Finally had to redo the stripes 10 years later. But they were 3M , not factory MINI.
OutMotoring
Mar 3, 2017 06:29 AM
gnhovis
Dec 14, 2015 05:31 PM
Tires, Wheels & Brakes
Oct 1, 2015 12:18 PM
tristanwelch95
Sep 30, 2015 08:58 AM
krohm
Sep 28, 2015 12:16 PM
