R56 ISO Headlight Lenses
Old Jul 19, 2015 | 02:08 PM
jeremy_reyes94's Avatar
jeremy_reyes94
Hi Guys I am in dire need of a headlight lens for and r56 please help if you guys have any links that just sell lenses, I couldn't find it in the Market place. Please Help
Old Jul 19, 2015 | 02:37 PM
rkw's Avatar
rkw
Just the lens by itself isn't available as a separate part. You'll have to replace the full headlight enclosure. That's how MINI receives it from their parts supplier.
Edit: BTW, the lens piece is glued to the enclosure and wasn't designed to be replaceable separately. People who do the "Joey mod" (black out the inside of the headlight) remove the lens by baking the headlight in an oven to soften the adhesive.
Old Jul 19, 2015 | 06:45 PM
jeremy_reyes94
That's what I did, but my lens was already messed up so looking for another one for
Old Jul 5, 2025 | 06:20 PM
darex's Avatar
darex
I baked the assembly three separate times (200°F for 20 mins), but the adhesive never sufficiently softened that I could separate the lens from the assembly, so I had to put it back for now. I'm stuck! I didn't expect removing the old lens would be the big challenge.
Never did find a clip I had to remove first, unless you mean the ones that hold the rubber ring/surround onto the assembly.
Might have to just dremel out the front portion and pick out the pieces at this point in limbo.
Old Jul 14, 2025 | 08:29 AM
We have the xenon ones here: https://www.ecstuning.com/b-bremmen-...02347698lens~/ 275 degrees for 10-15 minutes for removal, and 275 degrees for 5 minutes to rebake after the seal and lens are connected. Then let cool.
ES#3619826 for butyl tape.
We dont have the NON Xenon r56.
CarNutz
Jul 31, 2024 01:53 PM
smilinsteve
Aug 25, 2020 06:27 PM
rphox2003
Jun 24, 2013 09:52 AM
jtack
Aug 22, 2008 01:19 PM
