R56 3sdm 005 fitment issue! Need help!
Recently got 3sdm 005's 16x8 front and back, for my 2009 Mini Cooper s, they are wrapped in Yokohama s drives 195/40/16 the wheels and tires fit on the car great there's a problem, I want to have slight tuck and when I set my ride height in the front to tuck my skid plate is only 1/2 an inch of the ground and the car is undrivable I need to figure out how to get my fitment back in the front any ideas?
If you want tuck then you need a taller tire, which will look bloated, so you'll need a larger wheel diameter. You currently have *actually* low, not aesthetic low.
It also looks like you have either not enough positive offset in the wheel, or not enough camber to tuck a taller tire.
If you want tuck then you need a taller tire, which will look bloated, so you'll need a larger wheel diameter. You currently have *actually* low, not aesthetic low. It also looks like you have either not enough positive offset in the wheel, or not enough camber to tuck a taller tire.
Kimolaoha
Dec 5, 2020 09:32 PM
PelicanParts.com
Aug 25, 2015 02:46 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
