R61 :: Paceman Talk R61 Cooper and Cooper S hatchback discussion NOT REPAIR RELATED Discussions.
R61 First Post and First Need Of Advice
Old Jul 13, 2015 | 01:51 PM
ericcwhitaker's Avatar
ericcwhitaker
Talking First Post and First Need Of Advice
Of course my first post since joining would be a doozy. I need some advice and am hoping people here can help...
I have a 2013 Paceman S, love it and it loves me. However the other day I did a bit of accidental off roading off Mulholland in the hills of LA and ended up bottoming out to the point of getting stuck. Fortunately helping hands helped me lift/nudge the car off the peak, but along the way I scraped the bottom of the plastic trim pieces along the side of the car popping out a few pieces that hold it in place as well as shredding it in the middle.
My question is in essence is there any way that I can replace this trim piece at home and how would I go about purchasing one. I'm not a technical know it all, but I can find my way around mechanicals when I need to and I have a feeling if I take it to my dealer they will gouge me to death.
Insight appreciated!
Old Jul 14, 2015 | 07:49 AM
Which ones , take a look. If you damaged the under-body past the plastic or into metal or structural , I would turn it into the insurance as that could be an issues with alignment or the subframe. Could be much worse.
http://www.realoem.com/bmw/enUS/show...diagId=51_8300
You will not have a front pan #1 or the side pans #15 or #16.
Which ones were damaged ?
Old Jul 14, 2015 | 09:22 AM
ericcwhitaker
Thanks for the reply! I really appreciate it. I plan on having the car of course checked for damage, but it was a really light impact, more sliding along it than any jolt or direct hit. The piece that was damaged is the left door sill trim panel, shown here as 1. It's scraped up badly and a bit deformed underneath, and it is what took the impact from the curb.
Any idea on whether this could be a DIY or whether I should suck it up and let insurance handle it?
http://www.realoem.com/bmw/enUS/show...48#51779808935
Old Jul 14, 2015 | 09:27 AM
You are welcome, I would inspect the underbody, if its plastic, you can replaces it, if its body or metal or you pull back the plastic and there is stuff under the plastic damaged, I would make a claim. Its can get really expensive out of pocket.
If its just a plastic scrap or scuff , you can replace it.
51779808935
If its just #1 its a bunch of clips and trim pieces , not a big job. I would peal it off and look under to make sure there is no metal crushed. Otherwise its going to be the insurance.
I would inspect it more.
Old Jul 14, 2015 | 09:36 AM
ericcwhitaker
You are awesome for the reply. I will definitely crawl under there but I'm keeping my fingers crossed it's just that one piece. If not, here goes insurance.
Any idea where I could get instructions on replacing that piece on my own or is it really straightforward? Again thanks for your insight. I love my MINI and love that this forum is so friendly!
Old Jul 14, 2015 | 09:50 AM
Welcome.
The diagram linked is a good tool. it shows the points of the fasteners and clips it you study it. Peal back the bottom section. The top part of the rocker is a little more involved with the trim / rocker sill plates. Study it and compare.
The trick is not to break the clips or fasteners. If you do they will need replaced. Get a trim tool kit or something like it so you will have a better chance of not breaking things.
http://www.ecstuning.com/Search/SiteSearch/Schwaben_Trim/
Old Jul 14, 2015 | 09:55 AM
ericcwhitaker
Looks like i have plenty of homework! thanks again for the advice. I'll be doing my research asap!
Old Jul 14, 2015 | 10:01 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1 this is your best course of action.
Sometimes simple accidents like these can leave more damage than you think. Just make sure you get things all checked out and if there is more damage and your insurance deductible is low, it might be best just to make sure things are all properly fixed up. Good luck!
888.280.7799 | 6am - 5pm PST
Old Jul 14, 2015 | 10:26 AM
mikey_t's Avatar
mikey_t
It would be considered an 'at fault' collision claim so think hard before you put it thru your insurance policy.... it might not be worth the additional premiums depending on your insurance history.
Old Jul 15, 2015 | 08:25 PM
stage1scott's Avatar
stage1scott
I just bought a new Paceman too!
pm me here to hit me up, maybe I can help......
BucksCountyR57
R57 :: Cabrio Talk (2009+)
Sep 21, 2015 05:42 AM
KristaMcCoy
Sep 12, 2015 05:37 PM
