new x-lites/tpms - rubber or metal valves?
Hey all
I just picked up super clean R84 x-lites for a steal. Replacing worn runflats with 205/50s A/S in the next couple weeks.
My non-s had a leaky valve on my passenger rear R100 15" Spooler and my tire guys couldn't save it so they just replaced it with a normal rubber valve. My shop told me the stock valves always go bad from galvanic corrosion and said to look into rubber tpms valves. I took the sensor [which still is functional] and sourced exact oem BMW/Mini replacements that I'll be installing in the x-lites but the valves need replacement.
My question is has anyone switched from metal to rubber valves? I know I may be dealing with corroded valves on the other 3 Spoolers, also.
Looking forward to everyone's input. Love this site..
I suppose that you can go with the rubber valves to resist corrosion in your case.
But some say to replace rubber OEM valves with rubber not metal and vice versa:
http://www.discounttiredirect.com/di...TPMSArticle.do
But I finally was able to get my XLites installed. Just had Falken Ziex 905 205/50/16s installed. I picked up new 24mm valves and used oem tpms sensors off ebay for cheap. No more (!)
And the ride is so awesome now. No loud Continental runflats anymore!!
Sc00terbum
Sep 11, 2015 07:17 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 2, 2015 09:05 AM
