R56 R56 Engine light No fill
Old Jun 25, 2015 | 02:50 PM
Scott Zortea's Avatar
Scott Zortea
I will get a very little stutter from the engine the light will come on for a day
or 2 at the most then it is off. Dealer can find it and it will stay out for weeks or even months. Any thoughts ??
Old Jun 25, 2015 | 07:54 PM
minivinnie92's Avatar
minivinnie92
the dealer can or can't find it? if they can't best bet is to purchase or borrow a generic code reader than can read BMW codes and the second it pops up pull over read it. It can be a misfire code that clears it self up if they are wet and dry out or multiple other things best bet is to get a code. when the light comes on it just sputters a bit? does it have trouble starting when cold? any other issues?
also year? mileage? any recent repairs?
Old Jun 26, 2015 | 07:02 AM
Scott Zortea
it is an 09 86K miles and no repairs knock on wood
Old Jun 26, 2015 | 07:53 AM
ZippyNH's Avatar
ZippyNH
A stutter is usually a misfire....
After not seeing it a bit, the computer turns off the light,...
The info should remain for a bit, before getting overwritten...
Since it has happened more than once....
I would get a codereader....pull the code...see if it is always the same cylinder...
Maybe move the coilpacks...see if it follows the pack...
If it does not...need too look deeper...
Old Jun 26, 2015 | 08:03 AM
Scott Zortea
Thank You for you help I will pick one up
Old Jun 26, 2015 | 08:13 AM
ZippyNH's Avatar
ZippyNH
For as little as $30 you can get a basic one that does most stuff...very useful...
Harbour freight has a cheap unit that works fine. Think it is like $38 minus their typical coupon if one is in the area....Amazon is always an option too...
S OR NON S?
IF it is an S, a carbon cleaning might be in your future....direct injected motors have carbon issues on the intake valves, and fuel or cleaners in the fuel s does not touch them...so a different cleaning method is needed...the n14 s motor might be THE worst for this issue...
If a non-s, a shot of injector cleaner or a tank or two of premium gas might help.
In either case, keep your oil full, and clean...the MINI suggested oil changes are a bit longer than optimum IMO.
Old Jun 26, 2015 | 08:16 AM
ZippyNH's Avatar
ZippyNH
Coil pack can/will fail with age...not a huge deal...for an electric part, they sit in a terrible location...heat, vibration, etc...
If it does follow the coil pack when you move it, makes it a simple $100 fix...
Old Jun 26, 2015 | 02:32 PM
Scott Zortea
Thanks everyone lots and lots of help
Zettinger
Aug 25, 2015 04:04 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
