R56 Sprint booster 2 or D1 spec?
Old Jun 17, 2015 | 07:01 PM
Superdave88's Avatar
Superdave88
So i have a 2007 mini cooper non-S looking into either the sprint booster 2 or the D1 Spec .. which is better do they even makeke a D1 spec for a 2007 r56 mini coop hatchback on their site it only listed the clubman alittle help would be appreciated... think im going to get a DDM CAI unless the new Aem would work better but heard the air gets a little hotter.. as far as suspension parts think I'll go with the Hotchkis 25.5 mm rear sway bar any thoughts and suggestions i would appreciate ..i know its an automatic non s but the handling could be better in cornering .the throttle response could be alot better. And a cai would help it breathe a little better with a tiny bit of power increase...thanx all
Old Jun 17, 2015 | 07:52 PM
Mib4840's Avatar
Mib4840
I have the D1 on my R53 and love it. It has a lot more adjustability than the Sprint Booster. I adjust mine on every drive. It is a lot of fun going from economy to sport and feeling the difference in throttle response. I have the Hotchkis Sport 25.5 on order so,I can't tell you much about it yet. There are several write ups on it and that is why I went with it. As far as the CAIs I'm running an Alta so I have no info there for you. You will notice more performance with your naturally aspirated engine than we do with our forced air engines. I have had at least 5 different CAIs on different naturally aspirated engines and the smaller the engine the more you noticed the performance gain.
Old Jun 17, 2015 | 09:56 PM
Superdave88
so im guessing you either have a turbo or supercharged but you said i should get more out of a naturally aspirated engine and i heard the DDM was really good its closed off and looks almost stock and its a cai. Im also guessing the D1as far as throttle response.and last but not least th Hotchkiss rear sway bar which i believe is lighter and thicker but hollow but everyone says its the best so ..one question on the D1 on the sight i seen one listed for an 07 R56 clubman but nothing for the hatchback dont know if that would be the proper one or not unless u can leave me a link on where to get it for the best price plus be the right one for the car plus any links for the other parts would be appreciated.. thanx alot...
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
tEckniks
Sep 29, 2015 11:20 AM
krohm
Sep 28, 2015 12:16 PM
gnhovis
Sep 28, 2015 10:56 AM
