09 Cooper hesitates up to 2000rpm
Old Jun 16, 2015 | 07:57 AM
ainetsc's Avatar
ainetsc
We have a 2009 Cooper base which hesitates in any gear up to 2000 rpm, over 2000 rpm there is none.
We are getting 38 mpg with AC on as it's stupid hot here in VA so it does not seem like a misfire.
any idea's?
Old Jun 16, 2015 | 09:12 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
First thing I'd do is pull the spark plugs and see what they look like.
Old Jun 16, 2015 | 09:38 AM
Roca68's Avatar
Roca68
I had a similar issue. Replacing the spark plugs did the trick.
Old Jul 3, 2015 | 05:53 PM
ainetsc's Avatar
ainetsc
09 Cooper hesitates to 2000 Rpm
Plugs look well worn they have BERU plugs - ant recommendations for replacements?
Old Jul 12, 2015 | 12:01 PM
ainetsc's Avatar
ainetsc
Put new Bosch plugs In which did the trick - thanks!!!
Now to find that rattle from the boot area!!!!!!
Old Sep 29, 2015 | 10:51 AM
BossyR56's Avatar
BossyR56
I just got my car back over the weekend and they replaced the thermostat and coolant. No more loud sound when turning off the car however the car is hesitating starting at 2 rpms again. Spark plugs were just replaced in July ... and thoughts?
Old Oct 8, 2015 | 07:30 PM
Systemlord's Avatar
Systemlord
That aux pump for the turbo can buzz pretty loud when there's air in your cooling system. If you have ever had an aquarium you know those pumps buzz because there is water and air bubbles going through them.
Old Oct 8, 2015 | 07:37 PM
BossyR56's Avatar
BossyR56
Ended up taking the car back to the shop and they replaced the clutch. Didnt really think it was the clutch causing the hesitation but so far the car is running great! Knock on wood.
Old Oct 8, 2015 | 07:51 PM
Systemlord's Avatar
Systemlord
I had my clutch and flywheel components replaced recent and in second gear if you let it get to low in the RPMs it will start jerking back and forth, now that's a clutch with some grip!
Old Oct 8, 2015 | 08:00 PM
BossyR56's Avatar
BossyR56
How much did you end up paying if you don't mind me asking? The used car dealership whom I bought my mini covered the repairs.
Old Oct 8, 2015 | 09:15 PM
Systemlord's Avatar
Systemlord
I ran over a big tire on the freeway that was 100% percent unavoidable and that's when my throwout bearing started whistling/squealing, should have seen the Mercedes buck upwards that ran over the tire first! So my car insurance paid for the labor ($1900, Mini dealership) and $1400 for the parts.
I found many online places that sold the same geuine Mini clutch and flywheel parts for $869 (ECS Tuning ), but the Mini dealer wouldn't warranty a part that wasn't ordered through them even though it was a Min part.
Old Oct 17, 2015 | 07:47 PM
BossyR56's Avatar
BossyR56
They replaced the clutch. Problem solved.
Teh
Jun 13, 2018 02:59 PM
yashmack
Aug 15, 2015 10:16 AM
Aug 12, 2015 01:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
