Tech Tip and Brake and Exhaust Specials
Old Jul 30, 2004 | 11:56 AM
Casey's Avatar
Casey
Brake Fade Explained: Why and what to do
Once you understand the cause of a fading brake pedal you will see how easy it is to avoid it in the future. Brake pedal fade can occur for two primary reasons. The most common is the over heating of the brake fluid to a point where the fluid actually boils and turns to gas. The other common scenario is the over heating of the brake pad friction material to a point where it simply disintegrate from the pad backing plate....Full Story
Brake Performance Kits
PROMINI Stage 1 Brake Kit:
Front pads Mintex 1144
Rear pads Mintex 1144
PROMINI stainless brake line kit
2 Quarts ATE Super Blue brake fluid
For MINIs built through March 2003: Price: $359.78
For MINIs built from April 2003: Price: $359.78
PROMINI Stage 2 Brake Kit:
Front Cross drilled rotors
Rear Cross drilled rotors
For MINIs built through March 2003: Price: $521.69
For MINIs built from April 2003: Price: $521.69
PROMINI Stage 3 Brake Kit:
Tarox 318m floating front rotors w/ pads
Tarox 10 piston light weight front calipers
Tarox 323m floating rear rotors
Price: $2,943.72
Supersprint Exhaust System Specials
Supersprint Cooper Sport Exhaust System:
Center pipe & Rear Muffler
Supersprint Combo At 30% off (you get both pieces for only) $399.95
Supersprint Cooper Street Exhaust System:
Resonator & Rear Muffler
Supersprint Combo At 30% off (you get both pieces for only) $472.03
Supersprint Cooper S Sport Exhaust System:
Y-pipe, left & right sport mufflers, and your choice of tip.
w/ DTM Tips - Supersprint Combo At 30% off (you get all 4 pieces for only) $855.45
w/ BMP RS Tips - Supersprint Combo At 30% off (you get all 4 pieces for only) $794.66
w/ Dual Round Tips - Supersprint Combo At 30% off (you get all 4 pieces for only) $811.94
w/ Viper Tip - Supersprint Combo At 30% off (you get all 4 pieces for only) $859.92
H&R 18mm Adjustable Rear Sway Bar
35% Off Regular Price - Now only $146.25
10% Off Covercraft Car Cars & Colgan Car Bras
sevin
May 2, 2026 06:11 AM
stevepsd
35
Dec 6, 2022 03:22 PM
ASRman
Aug 13, 2015 09:33 AM
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
