Suspension Diy Adjustable Rear Arms
Old May 20, 2015 | 03:22 AM
Anakist's Avatar
Anakist
Hi,
I am making some adjustable rear camber / toe arms and want some dimensions:
Length of the metal bush the mounting bolt goes through to attach the arm to the car. I am guessing it is around 50mm / 2" because RealOEM says it is an M12x65 bolt holding them on.
If someone has aftermarket adjustable arms whether the heim joints / rose joints / rod ends are 16mm (5/8") or 20mm (3/4") thread.
Thanks!
James
Old May 21, 2015 | 05:53 AM
Saltysalt's Avatar
Saltysalt
trying to understand what your asking haha, fortunately I have some adjustable ones sitting outside of the car right now. you want to know the bolt length and the thread at the joint?
Old May 21, 2015 | 11:06 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Not sure how helpful this DIY is, but it might provide some good info in it. Probably getting your hands on a set yourself to take dimensions is a good idea.
-Luccia
888.280.7799 | 6am - 5pm PST
ebowling
90
Aug 4, 2019 09:15 AM
yukinoinu
15
Aug 24, 2015 09:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
