NM - RSE05 Pic Request and Reviews
Old May 16, 2015 | 11:48 AM
Rrotz's Avatar
Rrotz
Please post pics of your MINI with NM RSE05's in any color. I'm going to get the gunmetal greys for a Pure Silver 2004 MCS. Please show off your RSE05's and provide some feedback on these rims. Are they good? Are they bad?
I have no big brakes and just replaced all the rotors and pads so I won't be doing a R56 big brake conversion yet but I'd like to see the RSE05's please.
Old May 16, 2015 | 02:38 PM
spingq's Avatar
spingq
I'm happy with them - high quality, very easy to clean and its a nice touch that they work with OEM MINI center caps
Old May 16, 2015 | 04:03 PM
Joeygonz's Avatar
Joeygonz
Very nice!
Any side profile pics? Running on OEM tire size? Wheel spacers (15mm or 10mm)?
Old May 16, 2015 | 07:29 PM
Rrotz's Avatar
Rrotz
Oh man, FPNI! I'm sold, shut up and take my money! :D :D :D
More **** pics please!
Old May 17, 2015 | 05:54 PM
spingq's Avatar
spingq
Originally Posted by Joeygonz
Very nice!
You can kind of see in this pic that they are just shy of being flush with the wheel arches. My tires are 215/45-17. The wheels are 7.5" width and are equivalent to OEM offsets (+45) and will accommodate BB kits without spacers. I'm not running any spacers/no need. Most OEM MINI wheels in 17" diameter are 7" widths, so that extra .5" and going with 215s makes them sit a bit wider than you'll see most OEM setups w/o spacers. They are very light wheels for 17's - I haven't weighed them personally, but according to marketing, they are around 16lbs each.
Old May 17, 2015 | 06:08 PM
Joeygonz's Avatar
Joeygonz
Thanks for the post!
I am 50/50 when it comes to wheel spacers since it's best just to get the right offset. At 16 lbs. I would not argue about it being shy of the ¨flushed¨ look - still a very clean look!
Right on easy to clean...
Old May 17, 2015 | 06:19 PM
Rrotz's Avatar
Rrotz
more **** pics please spingq, i ordered mine yesterday just based on your pic (and a few others in the wheels post). how do they perform being so light? Are they just as durable or do you have to mind the potholes.
Old May 17, 2015 | 07:07 PM
spingq's Avatar
spingq
lots more pics in my gallery - https://www.northamericanmotoring.co...lery-4715.html
I don't drive too spirited, so performance was not a huge concern of mine. They certainly corner and hold the road much better than the stock 15's my car came with, but as with any smaller profile tire, it's best to take potholes as easy as you can... I'm sure they're plenty durable, but the best of rims can still be damaged from a pothole if you aren't careful enough. Apparently these have a 1 year warranty on the finish and 2 years on structural integrity, but I don't know how much "user error" that includes...
Old May 18, 2015 | 03:21 AM
Rrotz's Avatar
Rrotz
Awesome, I grabbed some caps of your ride. I'm just visualizing what it will look like when it's done.
Old May 18, 2015 | 08:52 AM
Grizld700's Avatar
Grizld700
Here are a couple pics of mine.
Disclaimer: It rained yesterday, so my cars not clean, sorry Also this is a quick couple cell phone pics with bad lighting. So I did have to adjust some color settings to make out the wheels since their black. Hopefully they don't look to crappy.
Side Shot:
Front shot:
I have 8mm wheel spacers on the front to clear the KW's I have. But my rear wheels don't have them.
Review: Wheels are really light. 16lbs is awesome. Lighter than my stock 16's. They have an awesome look.
Paint durability is ok. I got caught on a surprise gravel road one time and ended up with a few rock chips. I have the Matte Black wheels, so that paint may be less durable since it doesn't have the glossy coat over the paint.
I bought these when I had the rgular "S" body with standard matte wheel arches. But I recently got my JCW Black band kit that I had the arches painted gloss black so I'm wondering if I should refinish the wheels to something else.
Also, ignore the front bumper gap , I have a larger FMIC so I have do some trimming to do to the lower grille .
Old May 18, 2015 | 09:00 AM
Rrotz's Avatar
Rrotz
Very nice Grizld. Are those aftermarket front bonnet grilles and bonnet air scoop? Where'd you get the grille and scoop from?
Old May 18, 2015 | 09:06 AM
Grizld700's Avatar
Grizld700
The grille pieces are JCW and can be purchased anywhere that sells MINI parts. (Of course you will need the JCW Aero Kit to fit the lower grille).
The Notch Scoop I have I bought off a member here on NAM. I believe Outmotoring.com has these for sale.
Old May 18, 2015 | 11:06 AM
Rrotz's Avatar
Rrotz
I've heard they will fit the S model by modifying the bumper or the lower grille. Anyone know what that involves?
"Complete upper JCW grille kit containing honeycomb grille and upper and lower surround.
As included in the Aerodynamic bodykit.
Front bumper may need modifying if not fitting to a JCW aerokit. The clips on the lower surround will need modifying on either the surround of the bumper to fit."
I see in your sig that yours is a R56, mines an R53 1st Gen
Old May 18, 2015 | 11:24 AM
Grizld700's Avatar
Grizld700
Ahhhh, well then the Black out grilles for the R53's are easier. The lower portion needs a little modification, but not impossible to do by a DYIer. I had it on my R53 before I traded it.
And they do have a notch scoop for the R53 as well.
Old May 18, 2015 | 12:42 PM
EuroTechsAZ's Avatar
EuroTechsAZ
225/40 Hoosier R7 , fit with custom spacers. Looks mean and hooks up!
Only complaint is they are soft so they will bend but can be straightened without cracking.
Attached Thumbnails NM - RSE05 Pic Request and Reviews-2015-03-21-16.34.26.jpg   NM - RSE05 Pic Request and Reviews-2015-03-21-16.45.05.jpg
Old May 18, 2015 | 12:58 PM
Rrotz's Avatar
Rrotz
They are soft and they bend? How many times has that happened?
Old May 18, 2015 | 12:59 PM
Rrotz's Avatar
Rrotz
What'd you have to do to modify them? Possible solution is to get the JCW set and an aftermarket set and use the top JCW grille and the bottom aftermarket grille.
Old May 18, 2015 | 01:11 PM
Grizld700's Avatar
Grizld700
To be honest, I had a body shop do it for me. This was before I started to work on my own car. I'm pretty sure there is a thread somewhere on the forum here, but I haven't put my eyes on it. I don't think its too terribly difficult to modify however and looks the best using the JCW part.
I've also seen someone use the JCW top and PastiDipped the bottom.
Old May 18, 2015 | 01:19 PM
EuroTechsAZ
we typically bend one wheel a month. They are strong enough metal they don't crack. It is very common for good quality lightweight wheels to bend. If they crack it is typically due to cheaper quality light weight wheels.
They are repairable unlike cheaper wheels.
google "kosei wheels cracked" . They are light weight and cheap so they crack. NM just bend sometimes, I bend my OZ superleggera track wheels sometimes too. It happens from pot holes or rumble strips on track.
Old May 18, 2015 | 01:36 PM
Grizld700's Avatar
Grizld700
I've hit some pretty deep pot holes where I live and have no bends..... yet
Old May 21, 2015 | 05:23 AM
Rrotz's Avatar
Rrotz
How long have you had yours for?
Old May 21, 2015 | 07:38 AM
Grizld700's Avatar
Grizld700
Just a little over a year. I bought them used from a NAM member who owned them for an unknown amount of time.
Old May 21, 2015 | 08:12 AM
Those RSe05 's look great. Nice wheel from NM engineering and they have so many colors.
Old Jun 4, 2015 | 05:05 AM
Rrotz's Avatar
Rrotz
I got a set of RSE05's from my local MINI mod dealer, BLK Motorsports and did an unboxing and quick review on youtube of these wheels for anyone who's interested in getting them.
Neuspeed RSE05 in Gunmetal Grey from BLK Motorsports in Melbourne Australia
Old Jun 4, 2015 | 05:48 AM
RSE05's are a nice looking wheel.
