245/45/19 tires on 2015 Countryman
Old May 12, 2015 | 01:44 PM
Coopercountry's Avatar
Coopercountry
Does anyone know if 245/45/19 tires will fit without any rubbing on a 2015 Countryman S? All stock suspension no mods yet.
Old May 12, 2015 | 02:09 PM
MyroMini's Avatar
MyroMini
well, considering the standard size is 225/40R19, you will surely screw up your speedo with 245/45R19
That's over 6% difference in diameter. Over 3% is not recommended. Even more so with an ALL4 system
And you'll add more than 1.5 inches to the diameter
Old May 13, 2015 | 03:33 PM
bmwr606's Avatar
bmwr606
i am running 205/70R16 winter tires with OD of 27.3 inches and could not get any larger size od to fit without rubbing
245/45R19s are 27.8 inch OD and i do not think they will fit without rubbing also will probably rub on the struts on the inside and or fendrr on the outside due to the width
my speedo reads 0.9 mph UNDER actual speed with the 27.3 inch OD tires
Old May 13, 2015 | 06:15 PM
Coopercountry
Thanks for the info. I guess the 245/45/19's are out. I will keep searching for some decent 225/40/19's
Old Jun 9, 2015 | 06:44 AM
Dailey Kluck's Avatar
Dailey Kluck
http://www.tirerack.com/tires/tires....omCompare1=yes
kazyn
Oct 25, 2019 02:34 PM
peicraig
Canada
Aug 22, 2015 07:48 PM
col127
Aug 21, 2015 02:11 PM
Miniburb
Aug 7, 2015 03:45 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
